Installing Jeff's 2" Coild Lift - lots of pics
  • 22 Replies
  • 10015 Views
Offline MUD_TRACKER
  • 28
  • muddin in the ole tracker
Re: Installing Jeff's 2" Coild Lift - lots of pics
« Reply #15 on: July 30, 2011, 10:50:03 AM »
Jeff's 2" spacers and 31's
« Reply #16 on: October 21, 2011, 03:08:17 PM »
I am really interested in purchasing this lift....where can I get it at and how much is it?
Offline horseman
« Reply #17 on: October 21, 2011, 05:46:40 PM »
Search for Ebay ID: hoepkers. or try http://www.ebay.ca/itm/2-COIL-LIFT-KIT-98-OLDER-SUZUKI-SIDEKICK-GEO-TRACKER-/280752005988?pt=Motors_Car_Truck_Parts_Accessories&hash=item415e1fa364#ht_2728wt_1274
 I just got them for my 90 tracker and liked them a lot too.  I am on 235/75 r15 tires.
Offline canadiantbone
« Reply #18 on: November 02, 2011, 07:40:11 PM »
Nice write up ! plan on ordering a set for my 2000 tracker this weekend !
Offline zuki709
  • 190
  • 6
« Reply #19 on: November 03, 2011, 08:41:43 AM »
canadiantbone you should look at mudchild's kit. it is more expensive but has everything you need and is made out of aluminium and steel. I put one in my 2001 tracker last weekend and it went in good and looks awesome.
91 Samurai in many pieces
01 Tracker MUD CHILD's 2" suspension lift & 2" body lift. air lift air bag 1000 in front. 31x10.50X15 on stock samurai wheels.
« Reply #20 on: November 11, 2011, 12:02:55 PM »
will do , thanks for the info
Offline jesusno2
  • 16
« Reply #21 on: November 11, 2011, 06:42:19 PM »
Any competent real welder can weld cast. I've welded lots of cast manifolds before.  clean the joint well preheat area to be welded and i normally use lincon Ferroweld 1/8 rod weld it up let it cool natrually never had one come back yet.
Offline talonxracer
  • 1284
« Reply #22 on: November 13, 2011, 05:50:57 AM »
Bingo!
The problem most people have welding cast parts is improper preperation and not preheating the cast part enough prior to welding. I have seen several sammi cast thirds with mounting arms welded on for use in sidekicks and they have faired very well and there is far more torque applied there than on the mani.
