I HAD A PIECE WELDED IN MINE TO EXTEND IT THE 2 AND A WHATEVER INCHES THAT CALMINI SUGGESTED MATTY D...
when did calmini suggest this i have their lift and was unhappy with it because they left  some stuff out but. in the instructions they did state to drill out the plastic pins and heat up the shaft to remove the glue what they forgot to say was you had to knotch out for the t/case shifter and also for the tranny shifter
