My 'new' 94 sidekick
  • 1954 Views
Offline yellow2000S/R
  • 152
« on: February 07, 2012, 01:25:45 AM »
Back yet again, still have my 96 2 door Tracker that I'm building up... finally sourced a good D16z6 Honda crank after 4 months tho, bunch of flaky ass Honda owners.
ANYHOW, I picked up a 94 16v 4 door Sidekick JX for $1,000. Runs, drives, etc. Inspection is out, needs a new bolt/spring kit on the exhaust and donut gaskets for the downpipe. Also, after ~50 miles of driving it threw a CEL (code 51 I think it was) for the EGR system.
Tore the intake manifold off to get into all the ports in the underside of the runners and ALL were clogged, EGR was nearly clogged fully as well on one side.
Plans (getting rid of old parts from Tracker and selling the Sidekick to fund the Tracker build further).
Sell = Profit (hopefully) and put the money into a solid axle swap on the Tracker!
  • 152
Re: My 'new' 94 sidekick
« Reply #1 on: February 07, 2012, 01:26:02 AM »
Few days after I got it...
Now:
1 quart John Deere (Valspar) high gloss black mixed with 8oz of gray for the top half
Pinstriped wheels and between the paintjob
Valve clearances adjusted
New valve cover gasket
Recovered headliner
Newer fuel pump
NEW NGK v-power spark plugs
2" Low Range Offroad body lift
NEW Monroe front struts
NEW Monroe rear shocks
NEW Front rotors
NEWish front brake pads (few thousand miles)
15x7" Cragar V-5 steel wheels
30x9.5" BFG A/T tires
Fully cleaned EGR system (pulled intake mani, etc)
All new vac hoses
All new speaker wiring
CUSTOM 3/16" steel front bumper off my Tracker
5,000lb Warn Winch
Soon:
Pioneer headunit
Kicker speakers
JL 10w1 sub
Alpine amp
2" Low Range Offroad strut/spring spacer lift
Custom 3rd link spacer
Offline Derek
  • 63
« Reply #2 on: February 08, 2012, 07:42:13 AM »
If your going to put a 10" sub in I was able to install it in the rear door of my 93 four door and it works great. see my  post.
