1999+ Tracker 4Dr/4WD Auto/5Sp Lift - 2" Hoepker Spacers/OME Coils/Struts/Shocks
  • 1569 Views
Offline 40nTheFloor
  • 10
This is the path I am most likely to take to lift my 1999 & 2000 Trackers.  Both are 4Dr/4WD vehicles.  I prefer low center of gravity lifts and widening the vehicle stance to improve vehicle stability.  I made these same choices on my 1988 Cherokee and the improvement is tremendous.  I do not currently know stock axle or transmission ratios but, will get these later today or next week by visiting a local dealer with my VIN(s).  Here are the challenges:
1 - Wheels seem to be the largest challenge and this regards hub diameter (11 cm ~4-5/16").  What have people used when they use spacers or wheels that reduce OE backspacing/offset by 1-1.5"?  I may simply find axles to exchange or new axle gears to use if necessary.  I prefer the 15"" OE diamater with the correct offset/BS but, am finding the hub diameter on these Tracker's difficult to match.  This may force me to use spacers.  I have been searching for steel wheels because, these are usually stronger and always last longer before any form of corrosion begins to occur.  However, I have seen a few 15" alloy wheels with -19mm offset and this is the general idea.
2 - Tires - Not too large.  I will probably work with the 265/75R-15 or, 265/70-R15, and buy the tire with the highest load rating I can. This is not a small tire and I prefer to build both vehicles the same because, my wife will be using one.  This will make vehicle exchanges when one needs to be serviced easier to manage.  I have seen owners state these do not rub on these 2nd generation Vitara's when they retain the stock OE wheels so, this is part of the reasoning behind my choices.
3 - Hoepker coil spacers provide 2" whereas OME components result in 1.25" of lift.  Any potential conflict or possible component stress with this difference?
4 - Fender/quarter panel trimming?  I have found nothing useful on this topic.
Edit (1/8): Forgot to add axle gearing as an item!  Now I am adding fuel economy too.
I also found something useful in this Pirate4x4 thread:
http://www.pirate4x4.com/forum/suzuki/444978-4-door-sidekick-buildup-cool-daily-driver.html
It seems to discuss similar components used on a Sidekick.  However, OP seems to mention an issue with OME hardware resulting in a lower rear vehicle ride height than expected based on the parts he installed.  Maybe because, this dates back to 2006.  I do not see OME having an issue like the one he mentions in Post #3.  Perhaps this was made worse by his choice of GV front OME coils.  Nonetheless, it is a useful reference.  It even discusses some fuel economy from other contributors as well.  I should have added fuel economy to my list!
Please provide references to any useful work from others or comment in a constructive manner.
« Last Edit: January 09, 2018, 04:51:37 PM by 40nTheFloor »
Offline olija
  • 770
    • Check out my cardomain
1) Try to find a set of Jeep CJ 15x7  steel wheels. They have 3.75" backspacing and seem perfect on these rigs. Either that or run a 1" wheel spacer with stock wheels.
2) This is a popular tire size because it gives a good boost in ground clearance without requiring in-depth modifications to all kinds of other stuff. I don't think they'll fit without a lift, but you can try.
3) If you like the way the vehicle rides and handles loads and passengers, there is no reason to change out the springs. Spacers are cheap and get the job done. If you add spacers to OME coils you get around 2.5" lift and should add a set of diff drop brackets to keep the CV axles happy in the long run. Adding manual hubs will also help with this.
4) Trim as required.
5) Gearing- which gears are you referring to? Axle gears or transfer case gears? t-case gears are great if you're into rock crawling and don't like riding your clutch and brakes. They only help with your low-range though. If you get axle gears it helps with your all-around driveability but most people don't feel the need to regear with 29" tires.
Offline 40nTheFloor
  • 10
I think the OP (RM) used a 30x9.5R15 not a 29" tire on his Sidekick.  Gear ratio calculator's (such as http://www.grimmjeeper.com/gears.html) show that the 30" will result in the engine operating at lower rpm at highway speeds.  I cannot tell if this would also result in degrading the vehicle driveability because, I only have ~3 weeks of experience driving mine on 205/75R15 tires.  The OP makes no mention of this so, it seems reasonable to expect driveability remains good.
You make a good point regarding just adding spacers if I like the ride the OE suspension gives.  I had not considered this but, you still have to consider shock extension with spacers installed and I doubt that both OE shocks and the struts would be happy with this change.
The difficulty is the tire size I prefer (265/75R15) needs the 5.38 gears.  Suzuki did not offer this ratio for the G2, only for the Samurai.
Offline olija
  • 770
If you do a spacer lift, you can run longer shocks or shock extensions in the back. I believe shocks from a 1991 Ford Crown Victoria are what you want. Doesn't matter  if it's a police model or not, but I'd guess the police model had better valving than the senior citizen model.
In the front, you can put a strut mount spacer which effectively lowers your strut back to the position it was in before you installed the coil spring spacers. Or you can pay top dollar for Old Man Emu or LROR 1.5" longer struts. I'm not sure how much difference it makes on this front end...travel is nothing to write home about either way in my opinion.
As for your gearing- I would suggest that your calculations are incorrect. Both my 2001 Vitara 2.0L 5 speed and 2003 XL7 5 speed are running the same diameter tires as what you wish to run, and they were both regeared (Vitara went from 4.62 to 5.13, XL7 went from 4.30 to 5.13) and drive 100% like the day the rolled off the showroom floor. The nice thing is you don't need to look to the aftermarket for these gears- any 5-speed Sidekick or Tracker will have the 5.13 gears in the diffs and they are a bolt-in install.
