Audi Kick Re-Boot
  • 34 Replies
  • 16700 Views
Offline chadstichter
  • 162
  • 98 4door home built coil yota swap 31s rear e-lock
Re: Audi Kick Re-Boot
« Reply #15 on: September 24, 2012, 08:09:36 PM »
what lift and tire size is on this?
98 4door home built coil yota swap 31s rear e-locker, 8000lb winch and synthetic rope
|...BEER TRUCK..........| ||'|";, ___.
|_..._..._______===|=||_|__|..., ]
 l(|removethispart|@) (|removethispart|@)          l(|removethispart|@) (|removethispart|@)         l(|removethispart|@)
« Reply #16 on: September 24, 2012, 09:26:46 PM »
Right now it has a modified Calmini kit and 31's. A all new kit is currently going under it that will drasticly change the ride. Not sure yet how much lift it will have.
« Reply #17 on: October 02, 2012, 01:11:33 PM »
Took the kick on its shake down run this weekend at powerfest. right out of the gate I blasted down the gravel with Invicable on board to see what she would do. I had to re-use the Calmini rear springs as my new one's did not come in time. So the rear was pretty stiff. Even so, The front coilovers really soaked up the bumps. I can tell a HUGE difference with the extra couple inches travel, dual rate springs, and adjustability of the front end. I had a few small issues with the cooling fan control, the boost guage line fell on the exhaust and burned through, and the blow off valve fell off it's nipple. Nothing major though.
Dang this car is quick, even with no boost it's faster than my race kick. I can't wait to get the rear springs on and really flog this thing.
  • 162
« Reply #18 on: October 02, 2012, 04:28:43 PM »
could you post some pictures of the front coil overs?
« Reply #19 on: October 02, 2012, 06:44:51 PM »
Keep in mind this kit is still in development stages.
« Reply #20 on: October 02, 2012, 06:51:12 PM »
also the strut brace is custom for my car because of the audi motor. Bob is working with me to make a "long travel" version of his lift kit right now. We hope to see 13-15" of travel at the front. We already have seen over 13" at the rear with minimum mods.
« Reply #21 on: October 02, 2012, 06:53:27 PM »
Prototype rear
Need to move the shock mount up a little, and get softer springs.
  • 162
« Reply #22 on: October 02, 2012, 09:19:28 PM »
for some reason these pictures arnt working on my computer. is there any way you could pm them to me
Offline willzila
  • 40
« Reply #23 on: October 03, 2012, 10:54:52 AM »
So it's a kit? When you say development  stage are you implying it will be Avalable for purchase some time?
« Reply #24 on: October 03, 2012, 04:10:43 PM »
It's available for purchase now. Kreator is working on a longer travel version and I am one of his test mules. We will be changing a few things on this particular kit to suit my special needs car and driving style.
Offline willzila
  • 40
« Reply #25 on: October 03, 2012, 04:13:50 PM »
is it a complete kit? bolt on or no? man thats just what i was looking for, and to think i was just about to settle for the calmini kit
« Reply #26 on: October 03, 2012, 04:48:25 PM »
He offers serveral varietys. You can get a complete kit with coilovers, or a kit without coilovers(you use struts and springs). His front arms also are 1" wider and move foreward 1". The rear is also 1" longer. You can PM Kreator on here or I can PM you his phone #. The Coilovers are custom machined to work on a kick so you can't just get any old set. It is more expensive than Calmini's kit with the coilovers, but I prefer the ride quality in this kit. Just my .02
« Reply #27 on: October 04, 2012, 11:11:16 AM »
You can also order it in red and get the rear end put together without the 1" of rear spacing if you want.  :D
« Reply #28 on: March 31, 2017, 02:24:44 PM »
old thread but here are some updates for the few guys who still visit forums. I have had my buddy bob fab up a 3 link to install a 9" out of a 77 bronco.
It is only a few inches wider than the stock kick rear end
I also had him put in a GV steel front end
I have yet to re gear the 9" to match the GV 4.30. Right now I can say I need a clutch upgrade as the centerforce slips under high boost. I also need a master cylinder upgrade with the larger wheel cylinders on the 9"
« Reply #29 on: March 31, 2017, 10:13:58 PM »
You have a three link in the rear?  In the photo I see two upper links and one lower link.  I know the other end of the rear end isn't just hanging out there without any linkage.
I am interested in your setup.  It looks like your lower links go to the outside of the frame ?  How does it handle on highways, and higher speed backroads?  I have heard that it enjoys being pushed, but how does the linkage perform?
