Capt's Timber Cruiser
  • 20 Replies
  • 2120 Views
Offline Capt
  • 738
  • 28
Re: Capt's Timber Cruiser
« Reply #15 on: February 06, 2022, 11:43:33 AM »
Then I bought a left rear fender skin. This was a universal piece for a "Tin Top" but cutting it on the body line makes it a Soft Top piece
Offline Capt
  • 738
  • 28
« Reply #16 on: February 06, 2022, 11:46:34 AM »
Now, this is the First Time I have used 3M body panel adhesive instead of wire welding. My Rusty Iron Junkie Friend who owns a body shop told me to use this stuff as Welding always leaves places for Rust to Start !!
Offline Capt
  • 738
  • 28
« Reply #17 on: February 06, 2022, 11:50:39 AM »
This stuff IS Not Cheap......
The gun is $65.00, and the cartridges are $52.00 a piece.
But this Stuff is the Cats Ass !!
You Have to sand/grind both surfaces down to bare steel.
Offline Capt
  • 738
  • 28
« Reply #18 on: February 06, 2022, 11:58:27 AM »
Smear a very thin coat covering the bare steel on both the fender skin and the body. Then put two thick beads around the bonding points to get a Good Squeeze Out.
This is to make sure moisture can't get in.
ALSO have Someone Help You, and hopefully you did your several test fitting before this point, AS....
ONCE you set it against the body, you can slide it into alignment, BUT YOU CAN NOT LET IT LIFT OFF !! Air Bubbles and Tacky Points will not let you set it on straight !!
Being my First time doing this I got Happy Krazy with the Clamps
Offline Capt
  • 738
  • 28
« Reply #19 on: February 06, 2022, 12:01:49 PM »
A view from the back
Offline JollyZuk
  • 284
« Reply #20 on: February 11, 2022, 08:13:14 AM »
Looks good!  Rust eradication can be a pain sometimes!
1995 Sidekick JLX
OEM ROOF RACK!!!
