90 Tracker with Budget lift
  • 43 Replies
  • 41419 Views
Re: 90 Tracker with Budget lift
« Reply #30 on: March 11, 2012, 05:05:48 PM »
what did you use to cut the pig tail?  I'm wanting to do this mod.  Just need to know what I need to get this job done.
Offline Scotsmn
  • 29
« Reply #31 on: March 11, 2012, 06:07:11 PM »
I just used a cutting wheel on the grinder to cut mine.
Sold - 1990 Geo Tracker 2dr soft top - 3" homemade spring lift
New - 1992 Sidekick 4dr 16v manual - working on lift and motor
« Reply #32 on: March 11, 2012, 07:59:24 PM »
thank you, I was going to try tackling it with a sawzall.  I'm still about a month away from even making my junkyard run.  I want some warmer weather to do the work, I can't handle the cold.
« Reply #33 on: April 05, 2012, 06:47:44 PM »
Would you be able to add the two inch spacers to those springs for a total of 4" lift
95 kick 2dr 2.5 lift springs and 31 kumho m/t
Offline Scotsmn
  • 29
« Reply #34 on: April 05, 2012, 07:21:31 PM »
Not without making or buying some kind of drop bracket for your front diff as to add the extra lift would put your CV joints at an really bad angle.
« Reply #35 on: April 29, 2012, 07:06:03 PM »
Thanks for the help I got the springs on with 31s got to put my body lift on this weekend
Offline kreator
  • 634
  • 15
« Reply #36 on: May 01, 2012, 07:49:37 AM »
If you want some IFS drop bracket I have them and will sell a set $120
« Reply #37 on: July 27, 2012, 10:01:47 AM »
So assuming that you do get a differential drop bracket, is anything else needed to run spacers with the heep/Exploder springs.  What are the advantages/disadvantages to running a body lift instead?
Offline Scotsmn
  • 29
« Reply #38 on: August 12, 2012, 08:01:35 PM »
I don't run either a body lift or spacers so couldn't actually answer this, but if you do it, I would like to know how it turned out.
Offline Lanceuppercut06
« Reply #39 on: September 13, 2012, 01:44:52 AM »
Damn Definitely using this for my sidekick great and easy build bro nice job
Sometimes its not how fast or how expensive it is. Its not about the glits and glamour of bling or street glow. I just like running over shit.
Offline Scotsmn
  • 29
« Reply #40 on: September 13, 2012, 06:21:49 AM »
Thanks, I have put mine through the ringer and it is still going strong.
Offline brenzuk
  • 43
« Reply #41 on: September 13, 2012, 12:03:46 PM »
I would love to know how this works as well.  Also, how much lift on 4-door vs 2-door.
Offline Scotsmn
  • 29
« Reply #42 on: September 13, 2012, 12:10:02 PM »
With the rear I don't think you would have any issues. But explorer springs are a hair bigger than the original springs so not sure how well the spacers would match up to hold the spring in.
Offline tchajagos
  • 331
« Reply #43 on: October 16, 2012, 10:19:00 PM »
What back spacing do you have on your wheels? and did they have to be special ordered for the center hub to fit?
