90 Tracker with Budget lift
  • 43 Replies
  • 41411 Views
Offline Scotsmn
  • 29
Re: 90 Tracker with Budget lift
« Reply #15 on: December 14, 2011, 05:07:24 AM »
Yes, I did install the camber bolts and would say it is required as other wise the camber will be way off and cause bad handling and tire wear. I also installed the rear control arm spacer. I highly suggest this thought it will work short term without it.
Sold - 1990 Geo Tracker 2dr soft top - 3" homemade spring lift
New - 1992 Sidekick 4dr 16v manual - working on lift and motor
« Reply #16 on: December 17, 2011, 03:13:59 AM »
The Explorer springs came out of a 93 and 94. I believe the explorer and 4x4 ranger springs are all the same from 91 to 94 so any in that range will work.
The rear springs are from the rear of a early 90s cherokee but could not tell you the exact year.
also by 90s Cherokee, your talking about the front springs of the jeep? since the backs leaf?
sorry for the hardball lol i just wanna be exact at it
Offline Scotsmn
  • 29
« Reply #17 on: December 17, 2011, 07:55:02 AM »
The Jeep Grand Cherokee had coil springs in the rear from 93 on. The rear coils off of either a 94 or 95 Grand Cherokee is what I used for this build.
Offline dectar99
  • 104
« Reply #18 on: December 24, 2011, 04:18:07 PM »
Just a question..... why didn't you also use the jeep front springs, are they the wrong size or is there something else about them ??
Offline Scotsmn
  • 29
« Reply #19 on: December 24, 2011, 04:50:03 PM »
Jeep springs are way to light of spring rate for the front.
Offline dectar99
  • 104
« Reply #20 on: January 06, 2012, 06:02:51 PM »
Just a question for Scotsmn..... what about the front springs on a V8 Grand Cherokee the engine & trany weights more then the whole kick does...LOL  I would thnk that the spring rate would be fine
« Reply #21 on: January 06, 2012, 07:35:38 PM »
Nice work, I like using springs for lift.  They do improve the ride.
Your lift looks good.
Offline Scotsmn
  • 29
« Reply #22 on: January 08, 2012, 12:32:25 PM »
A solid axle doesn't put as much stress on a spring so thinking even the V-8 jeep will be about 100 lbs. light.
BRD HNTR, thanks and I agree it has made the ride better.
« Reply #23 on: February 22, 2012, 06:18:11 PM »
Did you have to do anything to the steering  or brake lines or anything else  ??? Or you just swap the springs
95 kick 2dr 2.5 lift springs and 31 kumho m/t
Offline Scotsmn
  • 29
« Reply #24 on: February 22, 2012, 06:24:30 PM »
Just Springs. Brake lines are plenty long enough and steering doesn't really change.
« Reply #25 on: February 23, 2012, 10:32:02 AM »
So it rides better than just putting the two inch spring spacers
Offline Scotsmn
  • 29
« Reply #26 on: February 23, 2012, 11:05:35 AM »
I never had just spacers on this one but have ridden in a sidekick that did and I think the ride is better personally on this one.
« Reply #27 on: February 25, 2012, 11:27:08 AM »
 Just got lift completed !! What a differenceit makes. Thanks Sotsmn for the help!! My son can't wait to get it out on the trails again it looks good, works good , and its CHEAP  I did mine for 250.00 total thats new parts from low range off road and new shocks too. THANKS again scotsmn and ZUKIWORLD you rock
Offline Scotsmn
  • 29
« Reply #28 on: February 25, 2012, 02:06:06 PM »
Very cool. Post some pics if you can as would love to see you finished product.
Offline mbja
« Reply #29 on: February 26, 2012, 05:42:18 AM »
really great idea, with the longer springs i can see you would get a way better rided as you are using more spring 'coils" then just adding spacers, have done the spacers on a couple of my kicks but will be going this way on my next one, thanks for info.
