Got my rig back up on jack stands today. I had the front all pulled out and painted the bare metal on the front part of the frame. Hooked up all the brake lines and shocks, slapped the front end back in. Went to build and upper shock bar and some shock tabs for the rear, and then realized that my rear shocks were a wee bit to long (12" is to much, had to go with 10"). So i called up Lowrangeoffroad and got some 10" shocks arranged.
After a semi good day of working on my rig i have this left to do:
Have a high pressure power steering hose made.
Install a power steering cooler.
Hook up oil pressure line.
Make shock bar and tabs for rear/install rear shocks.
Heat & bend pitman arm
Hook up diff breathers.
Add fluids to front & rear diffs
Make front Drive line
Cut out old tranny X-member
Fix Spidertrax E-brake
Re-do exhaust
Just fun little stuff that has to be done.
And i think that's pretty much the list for now, unless something else comes up.
Here's how its standing as of now.
I should be able to get it drivable under its own power with in the next 2 days.
Amilla
