82 SJ-410 build
  • 86 Replies
  • 24768 Views
Offline Jordan
  • 161
  • Chrome don't get ya home, but it sure looks nice!
Re: 82 SJ-410 build
« Reply #45 on: November 06, 2011, 11:35:47 AM »
Thanks BDR HNTR, I'll try ACK's, I also found a few good right ups on installing ARB's and 5.29's in Toyota 8" 3rds at www.gearinstalls.com. I think the only tools I need to get are a bearing separator and maybe a dial indicator, I have access to a press to press on the bearings and ring gear onto the ARB and the pinion. It would be easier to just take it to a shop but I know this won't be the last diff I'll have to get setup, so knowing how to do it my self would be very useful.
82 SJ410: 5" lift (spoa), home made cross over steering, bestop, custom rust lots of it,33"tsl, 6.5:1's. To install: Toyota diffs being built. To build: roll cage, traction bar, bumpers.
89 sidekick: lift 2"suspension 3"body, 31's, aluminum rims, warn hubs, (4) lights on roof, turbocharger.
Offline Jordan
  • 161
Re: 82 SJ-410 build
« Reply #46 on: November 13, 2011, 06:08:07 PM »
Look what showed up to day, A 81 Toyota pickup  :)...
Re: 82 SJ-410 build
« Reply #47 on: November 15, 2011, 09:42:59 AM »
It looks like the axles are about to fall off.  :D
Offline Jordan
  • 161
Re: 82 SJ-410 build
« Reply #48 on: November 15, 2011, 11:12:02 AM »
Ya if the rust doesn't get'em I will  ;)  but I think the diffs and front driveshaft are worth the $350 I payed for it.
Re: 82 SJ-410 build
« Reply #49 on: November 15, 2011, 02:05:29 PM »
 Get crackin' May is coming.  You gotta have it ready for the run.
Offline Jordan
  • 161
Re: 82 SJ-410 build
« Reply #50 on: November 15, 2011, 07:33:14 PM »
Ya my goal is to get the yota's under it and have it street legal by May  ;)   I'm going to grab a flashlight and go see what I can tear off the truck in the dark.
« Last Edit: November 16, 2011, 08:04:14 AM by Jordan »
Offline Jordan
  • 161
Re: 82 SJ-410 build
« Reply #51 on: November 16, 2011, 09:07:53 AM »
Well I got the 8 bolts off that hold the front  driveshaft on, but only got the diff flange end to brake loose so it's still on the truck, fighting with rusty bolts for 45 minutes in the dark at -10 isn't  vary fun.
Re: 82 SJ-410 build
« Reply #52 on: November 16, 2011, 01:07:57 PM »
Low Range sells adapter plates that will allow you to bolt them straight up to your stock drive shafts.  :)
Offline Jordan
  • 161
Re: 82 SJ-410 build
« Reply #53 on: November 16, 2011, 02:20:59 PM »
My driveshafts are a different bolt pattern then the 84 and up sj and sammys and I want the toyota cv drive shaft for the back  ;)  But that might work on my tcase (sammy case).
« Last Edit: November 22, 2011, 08:13:22 AM by Jordan »
Offline Jordan
  • 161
Re: 82 SJ-410 build
« Reply #54 on: November 22, 2011, 05:30:28 PM »
Well I got the front diff and drive shaft off, got the cv joint apart and the center ball that keeps both u-joints at the same angle is wore out so I'll have to see if I can get a new one. And I got both front knuckles off and the shafts out, I'll get some pictures of the size difference from the sj shafts (it's a lot).
Offline Jordan
  • 161
Re: 82 SJ-410 build
« Reply #55 on: November 26, 2011, 10:37:29 PM »
The front SJ shafts are 23mm thick, the yota's are 30mm thick, and the birfield 22mm wider then the SJ.
Re: 82 SJ-410 build
« Reply #56 on: November 30, 2011, 03:59:09 PM »
I think the U-Joints are the same on the SJ-410 and samurai, so you might be able to just swap the ends.
Offline Jordan
  • 161
Re: 82 SJ-410 build
« Reply #57 on: November 30, 2011, 07:06:15 PM »
That might work, I'll see if mine are the same as the sammys. Thanks Drone.
Offline Jordan
  • 161
Re: 82 SJ-410 build
« Reply #58 on: December 17, 2011, 07:45:17 AM »
Here's a list of the parts and tools I got so far: JD Squared model 3 tube bender, five Pro comp rockcrawler rims 15x8 2.5" backspace 6 on 5.5" bolt pattern, four Rancho 32" extended length RS9000 shocks, AllPro off road rear disc brake conversion,  new front brake calipers and roters. I should have the rest of the stuff ordered some time next week.
Re: 82 SJ-410 build
« Reply #59 on: December 20, 2011, 01:25:52 AM »
What size die did you get with that tube bender?
