Epic 2" Budget Boneyard Swap/Lift - 03 2DR Suzi - Longer Springs & Shocks
  • 40 Replies
  • 12274 Views
Re: Epic 2" Budget Boneyard Swap/Lift - 03 2DR Suzi - Longer Springs & Shocks
« Reply #30 on: November 03, 2015, 07:34:46 PM »
Nice looking skid pan.  I would recommend another bolt up front, as hitting anything with the skid pan is going to pushl it back from the front.  Then the force will be upward at the back where you have two bolts.  How far back does that skid pan go?  I have made mine to go all the way back and protect the transmission and transfer case, as I am running an automatic, and the transfer case hangs lower (and is aluminum).
Offline Junk-Yard-John (03-SWB Vitara)
  • 58
  • Get R Done - You Only Live Once
« Reply #31 on: November 04, 2015, 09:19:54 AM »
thanks hntr.  it will get more bolts up front for sure.  this one does not go far- just enought to protect the radiator, however i do have more sections of the aluminum chevy 1500 4x4 skid plates so i will likely add more when i can  ;D
2003 Vitara 2.0L 2DR trail buggy- 31.5"x16" E-rated tyres - Custom 2" suspension lift - 2000Lb  SuperWinch
  • 58
« Reply #32 on: November 09, 2015, 01:59:37 PM »
I didn't think it was ever gonna get stuck, I was wrong lol.   Had to use a loader tractor to get it out :D
Excellent budget build thread.
I am interested in seeing how well your front struts hold up.  I don't do any rock crawling and they may work for me.
I am also interested to see how well the rest of the aluminum skid plates are going to fit.
  • 58
hey guys
ive been using this vitara every chance i get to go trail riding, and the suspension has never let me down.  ive posted some videos previously of a dashcam in the rig, and recently i posted up a new video today
check out my youtube!
 youtube.com/MrJohn613/videos
https://youtu.be/57uWxmHS4DE
  • 58
some photos plus video links, feel free to SUBSCRIBE to my youtube channel.
https://youtu.be/Oo1a4QMNcGg
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
I just love these little trucks!
  • 58
my mom had a samaurai bush buggy when i was a kid, its in the blood i guess lol.  they are definately under-rated for thier capabilities.   ive only been stuck in this thing once, and shes been in some wild and mucky places.  lots of fun for sure
new video is live today
https://youtu.be/UUZgz3oJETk
check the link and SUBSCRIBE for future new video notifications ,
  • 58
« Reply #38 on: November 30, 2017, 08:39:58 PM »
I built a 60" 5ft plow out of scrap materials, the plow itself is the bottom side of a heating oil tank.  The framework is mostly 1/4" angle.  I also installed a larger 4000 lb winch which lifts the plow up and down. Manual 5 position angle.  Suspension works amazing.  Used it for 3/years, just sold the whole rig as a plow truck, but I'm replacing it immediately with a 2000 4rd gr vitara.  I will likely do the exact same lift on the next one, aside from possibly bigger front springs, since its going to be a 4/dr
Plow video finalé (part 6)
https://m.youtube.com/watch?v=NL1WY2_DffI
« Last Edit: November 30, 2017, 08:43:49 PM by Junk-Yard-John (03-SWB Vitara) »
Offline JollyZuk
  • 284
Have you started on your 4 door yet?  The Focus Wagon springs definitely interest me...I will have to start looking for a wagon at the junk yard.
1995 Sidekick JLX
OEM ROOF RACK!!!
Offline 40nTheFloor
  • 10
John,
Nice work and thanks for bringing these ideas to the community.  I have 2 4Dr/4WD Gen2 vehicles I am currently working on and need to know more details about what you did to your 2Dr.  First, what model year range on the Ford Focus wagon coil springs?  I think the wagon was a Gen1 vehicle only so, this should correspond to the 2000-2005 model years for the North American (NA) market.  I am uncertain about the model year range in other markets around the world but, it it apparent the Focus was initially introduced in the European market.  I found some information that suggests the Focus wagon may have been produced for the NA market until 2007 but, I need to confirm this.
The rear Grand Prix McPherson struts appear to be used on other vehicles.  Are you able to comment on this?
The steel wheels you mounted the 265/75R16 Goodyear's on are the 16" OE wheels for the Vitara or Grand Vitara in North America.  I doubt they have the offset or, backspacing necessary to clear these wider tires.  I saw a set of these at one of the local U-Pull salvage yards last weekend so, I will return there to measure offset/BS of these to see if I can answer this question on a broader scale.  I think tires in this size range require 8" rim so, this is likely to result in aftermarket wheel BS choices of 3.75" or 4."  Not many options here.  My only concern is if these BS measures result in contacting the front fender or rear quarter panel under full suspension flex.  I think your YT video stated you used bump stops on the knuckle to prevent contact with the frame at full lock?  This is what I would suspect might be required given contact on the frame as you approach full lock.  I am considering slightly smaller tires (i.e., 265/75R15 or 265/70R15) coupled to a small lift and your project gives me hope I might be able to make this idea work.  These tires are 1" and 2" shorter, respectively, than the 265/75R16 Goodyear's you began your build with.  This configuration is for the first vehicle, which will become my wife's so, she does not need rock crawling capability.
I know what the Fox body Mustang is so, this info helped.  A co-worker at my previous employer owns one.
After the experience you have gained with driving this offroad do you still think it is balanced well?  Meaning, as one example, did you ever consider looking into improved struts or shocks for these same vechile applications to improve the capability or your vehicle or the longevity of these parts?
Thanks again.  This is good information.
