So its been a while but I got some work done to the zuk.
The alarm is installed, just have to test the remote start and add the field disturbance sensor - No pics cause I am a ninja
Got the battery tray fabbed up (its plastic, not too hard) and the battery mounted where I want it:
Spent most of the last two days screwing around with this:
And now it looks like this:
Got the other battery cabling cleaned up and figured out:
Its a dual post battery on the drivers side that runs stuff, and the other battery runs the headlights, door locks, and other stuff. The headlights now work off of two separate fused relay's within the fuse box, and the door locks are the same. I also got rid of the "clicky starter fix" and used the starter relay that already existed in the fuse box.
My 200 Amp isolator relay should be in tomorrow. Why use a relay? Because it's better than an isolator. You wire each battery to it and then the ignition wire. Good to go and the batteries won't drain each other.
Uhh lets see, also got one of the E-Spec headlights in and working, just have to run wires to the other one.
Still more work to do, so stay tuned if you care to.
