Ok so I HAVE been working on the zuk.
Couple things I am working on:
I picked up a fuse/relay box from a 90's Rodeo, and I'm gonna make it work -
It's got six 5 pin 30A relay's and one 6 pin 40A relay, plus a bunch of fused outputs and two 80A fusible links. I have already figured out all of the wiring and I am going to use 5 of the relays. One for the starter (this means I can get rid of the "clicky starter fix" thing screwed to my firewall), 2 for the power door locks (currently they are fuel pump relays), and two for the headlights. That leaves 2 more for future use. There is also a diode and a wiper relay that I can use someday if I want to.
The box is small enough to mount on the passenger side, and it goes right up near the grommets that enter the cab, so the finished install will be clean and look factory.
I also bought a new battery with dual posts so I can run the main vehicle wiring off the side posts and add a power tap to the top post for the MB Quart AMP I just got.
