Kentucky Daniel Boone tour 2007!
  • 65 Replies
  • 12835 Views
Re: Kentucky Daniel Boone tour 2007!
« Reply #30 on: August 29, 2007, 10:54:14 AM »
My topo software wont export what I need so itt will take me a few minutes. I will post a brief trail routw with an over all map w/ approximate lat/long at key spots.
« Reply #31 on: August 29, 2007, 12:09:33 PM »
South Loop Road form R/R run form Zenith to Oneida:
1-From Downtown Allardt (last chance for gas, food beverage) at the intersection of SR 296 and SR-52 (N36^22.832â€? W84^53.074) head East on SR-52  for 7-8 Miles and look for signs directing you to ‘Zenith’.
2-At approximately N36^22.405’ W84^45.708 turn Left onto Noah Buck/Sam Smith Road.
3-Travel North and East along Sam Smith Road (will turn into Mt. Helen Rd) until arriving at Zenith Road (gravel) on your left (N36^24.290 W84^43.896’) (sign points ‘To Zenith’).
*Note* you will see on the map that there is al alternate entrance/turn off shown on the map prior to arriving at Zenith Road. Range Cenetery Road will dead end into North White Oak Creek at a (use to be) challenging creek crossing. I have not been to this location in 5-6 years so I do not know it’s condition. If you take this ‘creek’ crossing take a right on the trail after crossing the creek and follow it east until it connects with the directions below at approximately N36^25.734 W84^44.435.
4-Continue to follow signs/gravel road till arriving in an open gravel/dirt staging/parking area (1-1.25 miles) N36^25.340 W 84^43.849. *Air down here*. As you pull into the staging area you will notice the road/trail crossing a small creek to your left, this is the direction you will leave the staging area.
5-Leave the staging area by crossing the small creek and follow the gravel/dirt road to the ‘Creek’ (more like a river) Crossing   N36^25.734 W84^44.435
*NOTE* *WARNING* If it has been raining much in two days prior to your arrival at the crossing send the best equipped vehicle first!!!! In normal conditions, this crossing can be made by a stock Kick on highway radials (I did it) but can become deep after rains. Even at low water, stay on the apparent direct crossing between the in and out, there are deep holes just down stream form this crossing.
6-After making the crossing turn right (east) along the old R/R bed and follow it for the rest of your journey. You now have miles and miles of old R/R bed ahead of you with beautiful scenery to the end of the trip, with 1 catch ?.
7-While in Logging Hollow at approximately N36^27.323 W84^40.322 you have one more wide creek/river crossing.
*NOTE* *DO NOT FORGET THIS OR SOMEONE WILL SUBMERGE THEIR RIDE!!!!!!* At this crossing, DO NOT take the shortest line to the OUT of the trail. There are deep holes that will swallow 42’s. You need to make this crossing by driving perpendicular to the flow, bump up on the small under water rock ledge just left of the 4’ tall rock, then traverse down the far bank (around the BIG rock till coming out on the gravel).
Proper Crossing path (33’s)
Proper Crossing Path (35’s)
Just down stream of perpendicular crossing (42’s) and it got A LOT deeper about 15’ down stream
8-Continue along old railroad bed for approximately 1.5 miles till coming to the R/R bridge crossing. It’s old, but it’s safe! Don’t let the height get to ya  :o
9-Once you cross the bridge you can air back up, unlock the hubs etc…. Its all gravel from here.
10-Stay on gravel road (if in question follow the heaviest traveled or stay right). It will turn into O&W Road and take you into Oneida, TN where you will be cursed with paved roads again.
This trail can be taken in either direction as long as it is still open to vehicular traffic. PLEASE watch for Horses and stop the entire caravan and shut off all motors and radios while they are passing. This is a trail frequented by equestrian groups and they actually don’t mind courteous 4x4 groups and we would like to keep it as friendly as possible.
There are more trails West of Zenith but we have only aimlessly roamed these areas. The trails West of Zenith and ‘Up on the hill’ (you will know what I mean when you are there) are MUCH more challenging than the Zenith to Oneida R/R run. But they are a lot of fun to explore.
Like I said previously, I have not been there in a couple of years, and it has been an ongoing battle to keep this area open for years prior to my moving to Florida. So call ahead and confirm with the Big South Fork Park Services, that the “South Loop R/R Trail is still open to vehicular traffic. I will try to call and check for you sometime later this week.
HTH,
Map image to come.
« Reply #32 on: August 29, 2007, 12:28:31 PM »
Check your PM for a link to download the Topo Map exports (to large to upload and no access to photo editor right now  :P
Offline Jeff@TireBalls
  • 559
« Reply #33 on: August 29, 2007, 03:45:02 PM »
Awesome, between the way points and the maps I think I can figure this out.
Thanks for all your help and let me know if you talk to the forest service.
I hope it doesn't rain before I try it out, my GV with 29's may not like it much. Altho I do have a new snorkel installed that I haven't tried out yet.  :D
2000 Grand Vitara Limited, 2" lift, 225/75-16 BFG KO's, 5.12 gears, Safari snorkel, roof rack.
1987 Samurai LWB, VW 1.9 Turbo Diesel.
  • 559
« Reply #34 on: August 29, 2007, 04:39:24 PM »
Hows this look?
« Reply #35 on: August 30, 2007, 06:18:22 AM »
Looks great!!! A GV on 29's can make this entire ride with little or know trouble. The first crossing (no pictures shown above) is a wide flat crossing that I made in the kick w/ 29's in high water, but it was scary and on the verge of floating (water to door handles), but I had a support group of larger trucks that was ready to extract me if needed.
The second crossing (shown in pics above) is hard rock bottom, much narrorer than the first crossing and the deepest part of the correct path is shwn above with the Tundra in it.
If you do this section next spring or summer let me know, I will be glad to lead throuth this section.
  • 559
« Reply #36 on: August 30, 2007, 06:27:20 AM »
I'm sure well do a spring run as well.
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #37 on: August 30, 2007, 12:07:37 PM »
I am getting excited now...
Need to get to work on the Turtle!!
Bandit02
« Reply #38 on: August 30, 2007, 05:32:52 PM »
I'm already excited.... My GF is tired of me talking about it. lol
Offline wibornz
  • 55
  • 5 atvs and now a tracker
« Reply #39 on: September 01, 2007, 07:47:02 AM »
So what is the day that you guys are planning to do this?  A couple of us from Michigan might try and make it down.  We are putting body lifts on today and spring spacers in a week or two so we should be on 31 inch tires by the end of sept.  With this trip in OCT, we should be ready.
  • 559
« Reply #40 on: September 01, 2007, 08:01:07 AM »
It hasn't been set yet, I'm still waiting for more people to throw out dates.
Offline wibornz
  • 55
« Reply #41 on: September 01, 2007, 12:04:52 PM »
Well we can come on Oct 20 and 21.  It is a bye week for my kids football team.
« Reply #42 on: September 03, 2007, 03:04:07 PM »
That week is also good for my wife and I. We'll be coming from New Jersey. It's either this trip or were going to a place in KY., in Harlan Co.  Rather hook up with you guys.
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #43 on: September 03, 2007, 03:38:06 PM »
I am pretty sure that weekend would be good for me also!
I am supposed to race that weekend, but I already have the points sewn up in that region.
Bandit02
« Reply #44 on: September 04, 2007, 07:36:08 AM »
the 20-21 is perfect for me.. Can't wait for this trip to happen  ;D
