home made snorkel?
  • 12 Replies
  • 5727 Views
Offline allian
  • 70
  • love zukiworld! all the info you need.
home made snorkel?
« on: December 12, 2005, 10:46:06 PM »
i know i've seen a few kicks and sammies with home made snorkels... just wondering if anyone has made one for a 92 kick? if so what kind id tubbing did you use? meterials?
i really want to start swamping asap.  :)
thanks again!
Offline Dihnekis
  • 398
Re: home made snorkel?
« Reply #1 on: December 12, 2005, 10:57:54 PM »
There are tons of them, run a search. People just use some tubing, it isn't that hard and is pretty cheap to do.
1988 Suzuki Samurai
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
« Reply #2 on: December 13, 2005, 04:21:08 PM »
Here's mine (92 kick) if you have Q's, ask  ;)
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline allian
  • 70
« Reply #3 on: December 13, 2005, 06:34:32 PM »
YEAH! thats looks really good! just wondering what did you use for the top of the snorkel(dryer vent)?
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
« Reply #4 on: December 13, 2005, 06:41:48 PM »
here are some pics of my snorkle i have been running it for about 2 years no problems unless the mass airflow sensor goes then u have to disconect it.
here is a link to my page http://www.cardomain.com/ride/769479/2 if u rock crawl a hand throtle my be another good idea.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline trailtracker
  • 44
  • the fixing/modification is endless!
« Reply #5 on: December 13, 2005, 08:22:12 PM »
i have a similar set up to tracker8wr except i used exhaust flex pipe. 2-1/4 and i bashed my hood a little to fit it. dont have a fitting on it i just run it straight back, i havent tested it for complete suction, im sure pvc would work  better, but its better than stock. it i stick hold my hand over it, it sucks really hard so i know it works better than no snorkel. just remember if you are traversing deep water, anything you have is better than nothing and blowing a hole in your motor.
Unsafe at any speed
Offline ed oorklep
  • 637
    • Suzuki Vitara 4x4
« Reply #6 on: December 14, 2005, 01:28:21 AM »
Thx, top it just a 45 degree elbow with some bits cut out of the walls (at the top), to let the air through. And on top of that a cap that normally will be fitted to a larger pipe to close it off. All glued together  ;D real cheap, set me back maybe 20-30 bucks  ;D
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline wolf66
  • 193
« Reply #7 on: December 14, 2005, 01:03:52 PM »
Some Lowes carry ABS tubing which looks much better then PVC, mine came out like this:
'96 Suzuki X90-4" lift-snorkle-30x9.5's on 8x15 wheels-5.12 gears-winch-added rear seat-DT header-PioneerMP3-CB-GPS-roof rack-rear mounted full size spare
Offline bandit86
  • 1641
  • elv8rguy
« Reply #8 on: December 14, 2005, 02:06:13 PM »
it's easy, just measure 3 times, and cut once.  probably better if you do a mock up first
Offline allian
  • 70
« Reply #9 on: December 14, 2005, 04:09:29 PM »
you guys have been a BIG help!
thanks! ;D
Offline echojeff
  • 414
  • Lo que sea
« Reply #10 on: December 14, 2005, 09:47:06 PM »
WHO NEEDS A SNORKLE?
check this out...
http://videos.streetfire.net/player.aspx?fileid=3676567A-C37F-4EC0-BCE0-EDB4400C7BBD
Ok, I thought my air intake was near the firewall in the fender well, not behind the headlight.  It was my first time out wheeling.  I had a jeep friend with me in case somthing happened.  That was only suppose to be 2 ft of water.
95 Kick 4dr JLX.
Offline de Ploeteraar
  • 10
    • de Ploeteraar
« Reply #11 on: December 15, 2005, 02:06:59 AM »
Hello,
Look for more details my homepage! www.ploeteraar.nl
click on the left side "techniek" (second button) and click on "snorkel" on the left side to (first button). There are somthing pictures of my homemade K&N snorkel.
For guestions mail!!!!
De Ploeteraar
www.ploeteraar.nl
(Dutch Vitara website)
Official test driver  www.Hillbilly-engineering.de
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« Reply #12 on: December 15, 2005, 04:24:10 PM »
Very nice job de Ploeteraar. 8)
For us english speaking folks, go here:
http://www.systranbox.com/systran/box
Paste this http://www.ploeteraar.nl/techniek/snorkel.html in the web page box.
Select "Dutch to English"
