Stans toyota CV swap kit (pics)
  • 73 Replies
  • 31718 Views
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« on: October 24, 2005, 01:04:23 PM »
This is where the inner Toyota cup mounts.
The brass sleeve replaces the stock brass sleeve located at the back of the hub bearing. The larger steel piece is the lockout spacer. The toyota's outer stub is longer.
I will get some pics of them installed posted on wednsday.
Mike
Offline explosivo
  • 3157
Re: Stans toyota CV swap kit (pics)
« Reply #1 on: October 24, 2005, 02:48:14 PM »
So what's the going price for the kit? How about just the lockout spacers for the guys looking to swap in the Toy diff as well?
omghi2.us[/url]
Offline brlj
  • 512
    • Bills 93 Tracker
« Reply #2 on: October 24, 2005, 05:43:40 PM »
Heres a pic of the driverside cv adapter and locking hub adapter mounted.
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #3 on: October 24, 2005, 07:40:09 PM »
$300 I belive. Stan is 37Kicker on this board. You could PM him if your interested.
Mike
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #4 on: October 24, 2005, 07:42:46 PM »
Thanks for the pics Bill! I guess thats one less thing to do on Wendsday! ;D
Mike
Offline ksa421
  • 382
« Reply #5 on: October 24, 2005, 07:45:48 PM »
Could you post pics of any grinding and mods to the a-arm you did?
'90 Kick, Calmini 6" lift, 32x10.50 Pro Comps, Calmini bumper, 8000lb winch, 1.6l VW TD;
Offline 37kicker
  • 319
  • 97 tracker 9inch front and rear on 40" pitbulls
« Reply #6 on: October 24, 2005, 07:49:35 PM »
I could be talked into selling parts of the kit for those interested in that . mike is correct 300 plus shipping  stan
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #7 on: October 24, 2005, 07:53:44 PM »
I have a pic but the file is too big to post. I can resize it tonight as the computer im using tonight does not have a photoshop editor. KSA421, I just emailed you the pic.
Mike
« Last Edit: October 24, 2005, 07:56:31 PM by Mikerpm4x4 »
Offline Chief
  • 678
  • Whaddya lookin at??
« Reply #8 on: October 24, 2005, 08:06:57 PM »
As far as the Toy CV's are concerned, which ones would we need for the swap? What yrs.
Also, are they the same for each side, as in, only need one spare? And how would the CV's work with the Hagen widing method??? Would the CV adapter need to be made thicker?
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #9 on: October 24, 2005, 08:18:50 PM »
It actually reqires the widening mod, so if youve already done it your halfway there. CV shafts are from 86-94 I belive.
Mike
Offline echojeff
  • 414
  • Lo que sea
« Reply #10 on: October 24, 2005, 10:01:18 PM »
Ok I know I may be missing somthing here, but what are actual benifits to using the yota cv's?  Bigger tires? how big? I know that stock cv's can safely run 31" tires, so what will the yota's do?  Is this better than the ford ranger or maxima cv's, and what tire sizes can they run, safely? What do you do to the rear to match the strength of the new front end?
Jeff
« Last Edit: October 24, 2005, 10:02:50 PM by echojeff »
95 Kick 4dr JLX.
Offline Hawklin
  • 109
  • If it cant be fixed with Duck Tape it aint broke
« Reply #11 on: October 24, 2005, 11:53:58 PM »
I've seen guys running 37's on a IFS toyota with a fairly hopped up V-6 and never snapped a CV even with romping pretty hard on em. Other than that I'm only running 31's on my toy but never had an issue with a CV in the 8 years I've owned and abused mine.
Rob Cross
90 Tracker (sold :()
91 Toyota 4x4 bone stock other than a redneck lift(cranked T bars and a block in the rear) on 35's
Offline Chief
  • 678
« Reply #12 on: October 25, 2005, 08:01:29 AM »
Jeff
To match the front overall strength, I'd say probably the calmini rear axles. Or a Ford 9".  8)
I would feel much more confident running 33's and a front locker with this mod, which may change my mind on going SAS! (At least fir awhile  ;))
Offline Chief
  • 678
« Reply #13 on: October 25, 2005, 08:02:27 AM »
Mike
Excellent! Easy to do all at once then. I think SAS may be put off for a bit!
Offline Hawklin
  • 109
« Reply #14 on: October 25, 2005, 08:43:55 AM »
I'm looking to do a whole toyota ifs diff and rear axle swap(have a guy that is doing a SAS on his Toy with dana 44's), was just curious if anyone knew if the front axle and diff would work with just the widening mod and spacers from Stan? Just holding off on this till I can get me a welder to start making the new brackets to hold in the toy diff. I was actualy messing with the idea of somehow using  the toyota knuckles also but if it would all fit in ok would save me alot of Fab time.
Rob Cross
