Cheap motor mount fix.
  • 6011 Views
Offline DART451
« on: September 30, 2005, 11:52:04 AM »
I noticed my driver side motor mount was broke, and wanted to go muddin. So call local stores and no store in town had a motor mount. I started looking around my garage and found a small block dodge dart motor mount that worked great. Had to drill out the holes to 1/2" (has studs on both sides), and best part is that they are alot cheaper then the $40+ that I was quoted. Just wanted to pass this on if you are in a jamb or just a cheap skate like me. :D
Offline 92Sidekick4x4
  • 1456
Re: Cheap motor mount fix.
« Reply #1 on: September 30, 2005, 02:20:12 PM »
40 bucks for a motor mount for a sidcekick is cheap! brand new that is, when i needed one i was qouted from 3 places and the cheapes was 185 bucks, so i went ot a wrecker and paid 20
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #2 on: September 30, 2005, 04:10:15 PM »
Some years back, i needed some mounts for my sami, and by searching the net, found that old dodge and chrysler V8 mounts could fit.  I found some for about $6 each and bolted them in after drilling out the main hole and getting nuts to match the mounts.  Cheap as chips.  These are always in stock at auto parts stores.
Now i never did try them with a kick mount though.  Not sure what the size difference was, but sounds like it could work as long as it fits pretty well.
1993 4-door Sidekick
4.24:1 t-case
Offline explosivo
  • 3157
« Reply #3 on: October 01, 2005, 11:08:34 PM »
This is my solution for a cheap set of motor mounts. Cost about $20 for both sides, including the steel, bushings, and bolts ;D
omghi2.us[/url]
Offline DART451
« Reply #4 on: October 03, 2005, 05:20:25 AM »
Nice to see we are all cheap ;D
Offline crikeymike
  • 713
« Reply #5 on: October 03, 2005, 12:08:24 PM »
now all he needs is some JB weld for the "holy" exhaust manifold...
4.24:1 t-case
Offline SnoFalls
  • 1358
« Reply #6 on: October 03, 2005, 12:56:55 PM »
nah booger welds ... cheaper than jb  ;D
