Gas mileage...whats yours?
  • 45 Replies
  • 6746 Views
Offline zaggy
  • 1134
« on: July 18, 2005, 04:15:49 PM »
It's been bugging me.....
     That I seem to be getting dramatically better gas mileage than everyone else that I've heard comment.......then it dawned on me.......I work out everything to a CANADIAN gallon.
The Canadian gallon is 20% bigger so my 38mpg is really 31mpg US gallon
Hows that compare?
The wifes unit is a 1992 SideKick 4 dr, 1.6/16v, 5 speed, 4X4 of course.
- P215-75-15 all terrains
- K/N Aircleaner
- 2" Exhaust with Turbo muffler
Zag
Offline cj
  • 1276
  • I drive a really big ATV
Re: Gas mileage...whats yours?
« Reply #1 on: July 18, 2005, 05:11:42 PM »
My '93 4dr 1.6 16v auto
-31x10.5 Muddies
-5.125 Diffs
28mpg US
Offline Suzuki1.8
  • 283
  • Tires so low looks like i'm riding on blades
« Reply #2 on: July 18, 2005, 05:28:38 PM »
my 97 sidekick sport 4dr 1.8liter gets 26mph 225/30/20 tires
Offline echojeff
  • 414
  • Lo que sea
« Reply #3 on: July 18, 2005, 05:48:51 PM »
95' 4dr kick JLX 5speed 16v 1.6
215-75-15 wranglers
27-28mpg, but my speedo is ailing.
Went on a 340 mi trip to the mountains, with about 20mi in 4wd, 60mi more on dirt road,
crossing the Colorado continental divide 3 times, and a pass at over 12,000 feet, 30.4 mpg!
Zag, you get better mpg than me. I need to get a new cat back system, I was thinking of calmini's.Do you have a better suggestion?  About 2 ft of my tail pipe rusted off, and looks as if there is rustage around seam of the muffler. Is your k/n filter a separate unit or a drop in the old air box kind.  After reading about the snorkel thing, does the zuke need that box and other extra tubing in the wheel well? I am also looking at new tires before winter, and I want 235's but I worry about rubbing.  I am thinking of doing the spring spacer thing this winter. Would that help?
Jeff
95 Kick 4dr JLX.
Offline Agent Orange
  • 711
    • Trying to learn
« Reply #4 on: July 18, 2005, 06:07:56 PM »
ok zaggy
33 litres took me 382km do the math for me thanks in mpg
Offline zaggy
  • 1134
« Reply #5 on: July 18, 2005, 06:36:21 PM »
Thats 25.4 mpUSg according to my calculator...
Zag
Offline derekj
  • 784
  • i'm the canadian guy eh?
« Reply #6 on: July 18, 2005, 06:50:41 PM »
our gas mileage is around 25-28mpg with 31's and a five speed
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline trackinstile
  • 435
« Reply #7 on: July 18, 2005, 06:55:12 PM »
I get between 25 to 28 the best in my 2000 with the four and a stick and my wifes XL-7 with an automatic and power everything gets about 21 sometimes a little better sometimes a little worse, but never less than 20 ;D
« Reply #8 on: July 18, 2005, 07:36:29 PM »
Mine is an 89' automatic TBI 1.6 8V
brand new never got better than 23
mostly 21-23
Now with 33" tires, 5.83 gears total
of 7 inches of lift and the turbo I get
18-20 highway, all considered I didn't
think that was a big MPG price to pay
for the mods, and the power, well it's
worth the drop to pass Jeeps on the
Steeps   ;D
Offline zaggy
  • 1134
« Reply #9 on: July 18, 2005, 08:21:14 PM »
Echojeff
     The Calmini stuff looks good but I've never used it. I always get my stuff done locally because
1) I'm cheap
2) I always try to support the local racers that support me and there's a bunch in the exhaust
    biz.
    If it was me and you have a good exhaust shop that the rodders and racers use I'd go for a 2 1/8" tube from the CAT back and use a "Turbo Style" good quality muffler....my complete system from the manifold back...installed...only cost $200.00.
    If there is no one in your area with a good rep or they are crazy expensive the Calmini system does look like a good option...ask around on the board for guys that have used it.
     My airfilter is the KN replacement filter in the stock airbox with a couple extra 2" holes drilled in it.
     I use NGK plugs ( the V fire not the platinum or multi prong) NGK 8mm wires and keep the pig in time and clean.
By the way I cruise the Hi Way at 120-130km (about 70-75mph)
Zag
  • 711
    • Trying to learn
« Reply #10 on: July 18, 2005, 09:57:34 PM »
Zag
thanks zag
that's pretty good milage for me considering it's all city miles in vancouver with all the hill and traffic. i also drove it harder during that tank of gas, usually i'm lite on the gas pedal and never rev it past 3000rpm. i also fill it way before it needs to so i never really new what my milage was, i always figured it was around 25mpg  :)
i'm going to be installing my calmini header in the next few weeks, and a complete new exhaust 2" with a high flow cat, and muffler. i can't wait to see what kind of power, and milage gains i get.
Offline zaggy
  • 1134
« Reply #11 on: July 18, 2005, 10:06:31 PM »
Awesome....that should make a big improvement if you don't drive the !|removethispart|@$%^ outof it with all the new found power.
Zag
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #12 on: July 18, 2005, 10:19:22 PM »
the goblin running 33's on a 8 valve engine, 5spd and 5.12's, with K&N drop -in filter and a header with full 2-1/4" exhaust, through all the hills around here, I get about 17mpg without correcting for the speedo being off 15mph at 60mph...
  • 711
    • Trying to learn
« Reply #13 on: July 18, 2005, 10:23:15 PM »
yup after hearing a few times on this board how a cat back makes a huge improvement. i'm doing a complete upgrade from head to tailpipe. i'll report in after the installation.
Offline ksa421
  • 382
« Reply #14 on: July 19, 2005, 02:00:52 AM »
With the 8v and 32s i got about 20mpg, but as soon as I get diesel swap on the road I should get over 30 I was told.. :)
'90 Kick, Calmini 6" lift, 32x10.50 Pro Comps, Calmini bumper, 8000lb winch, 1.6l VW TD;
