Advice on lifting a 94 tracker 2dr
  • 1481 Views
Offline hwyman
  • 175
« on: October 07, 2011, 07:10:55 AM »
I want to add about 2" of lift to my 94 tracker 2dr 4wd.  After reading multiple post on here I think I have a couple options for a suspension lift.
1 buy a spacer kit, use 94 crown vic shocks on rear and stock struts on front.
2 buy a set of springs from a 4dr tracker use them, shocks for 94 crown vic on rear and stock struts on front.
         my question on this option: are the 4dr springs a simple bolt on or do I have to do a lot of fab work?
What is the general consensus on the best route to go?
Any advice and pics would be greatly appreciated
Travis
1994 Geo Tracker  2dr 4wd 1.6l 8v Manual Trans
Offline airmanwilliams
  • 913
Re: Advice on lifting a 94 tracker 2dr
« Reply #1 on: October 07, 2011, 08:36:30 AM »
I would go with spacers. the guy that had my 4door before I bought it even made his own spacers out of pipe laying around the house. if you search etdavenport on some of the forums he has pictures up of it but I cant remember where. and you can just flip the front strut mounts for the strut mount spacer that is needed.
1993 4door Suzuki Sidekick JX
Offline horseman
« Reply #2 on: October 07, 2011, 07:13:31 PM »
I just bought and installed the 2" spacers of ebay.  They were the cheapest I found and had good reviews from others.  It was an easy install and I'm happy with them so far.  It's only been a week of driving on them though.  I just started the Huntin Rig build if you want to see before and after pics.  I don't have any closeups while doing the install though.
« Reply #3 on: October 10, 2011, 03:49:10 AM »
Spacers are the best bang for your buck, but they do ride a bit harsher then a true spring lift.
Offline MUD CHILD
  • 355
  • 9
« Reply #4 on: October 10, 2011, 11:56:20 PM »
If you are looking for a good quality spacer lift tale a look at SR CUSTOMS: http://www.srcustoms.ca/index.php?page=shop.browse&category_id=7&option=com_virtuemart&Itemid=56
NO DITCH TO DEEP NO HILL TO STEEP
http://srcustoms.ca/
