rocker screws?
  • 2767 Views
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
rocker screws?
« on: November 08, 2009, 03:24:49 PM »
took off my valve cover for the first time and some of the screws that hold the rockers down r missing       so can some one help with the size   thread   and length            87 samurai 1.3
Re: rocker screws?
« Reply #1 on: November 09, 2009, 04:51:08 PM »
I looked at mine to see if I was missing any screws, all there: but one is a cap screw.  Not a tapered head.  Will this screw up my rocker?
  • 6548
  • 64
Re: rocker screws?
« Reply #2 on: November 10, 2009, 07:34:19 AM »
It is common for those screws to be loose on engines with some miles on them. I've even found them in the oil pan before! A bit of medium locktite and an impact driver to tap them in just a bit tighter than you can do with a screw driver and they'll be fine. To get replacements, Call Hawk.
Good luck, Eric
Re: rocker screws?
« Reply #3 on: November 12, 2009, 03:17:55 PM »
On the later models the factorys started staking those bolts.
Re: rocker screws?
« Reply #4 on: November 13, 2009, 05:29:34 AM »
Thank You for that tidbit of info.
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
Re: rocker screws?
« Reply #5 on: November 13, 2009, 03:44:49 PM »
i was looking for the size and thread pitch hawks  would not say they want me to buy some from them
  • 6548
  • 64
Re: rocker screws?
« Reply #6 on: November 16, 2009, 07:56:17 AM »
How much are they asking for those screw/bolts?
Re: rocker screws?
« Reply #7 on: November 19, 2009, 11:49:49 AM »
I found the same thing on mine. Half of them were loose, but half of them have been OVERTIGHTENED and wont budge with an impact driver. I've brocken two  phillips heads trying to loosn them and stripped out some of the screws. I need to replace a few rockers so will have to loosen those grub screws somehow.
If you are planning to use loctite and impact to hold those screws in, maybe you should use a hex screw or torx head or something that will easier to remove in the future.
