Sensor light came on the dash instrument panel why???
  • 9 Replies
  • 1843 Views
Offline Hitman
  • 17
« on: May 16, 2009, 11:17:08 PM »
WTF???  Sensor light is now on where do I fix it?  Where does it go to what sensor under the hood?  Thanks for your replies in advance...
Offline robbin
  • 33
Re: Sensor light came on the dash instrument panel why???
« Reply #1 on: May 17, 2009, 11:59:51 AM »
What kind and year zuki if its a carbed Samurai its like a service light and there should be a switch under the dash on the steering column to turn it off.
Offline fuzzy1
  • 350
« Reply #2 on: May 17, 2009, 09:11:28 PM »
Yep, could be the SES nag light, or it may have thrown a code. But yeah, tell what year/make/model/engine/valves & tranny . Kinda hard to help with no idea what vehicle it is.  ???
Non Illegitimi Conterat
Offline Hitman
  • 17
« Reply #3 on: May 19, 2009, 02:06:34 AM »
It is a 86 Sammy 1.3 weber carbed 5 spd...  Thanks
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #4 on: May 19, 2009, 05:43:31 AM »
There is a small slide switch under the dash next to the steering column.  Slide it to the opposite position and the light will turn off.
This is a "Nag" switch.  It turns on when the odometer increments to a multiple of some large value.  It is telling you to look at the owner's manual and perform maintenence at the indicated mileage.
Ack
Offline Hitman
  • 17
« Reply #5 on: May 20, 2009, 09:44:13 PM »
Man I cant find that damn switch...
Offline ppilotmike
« Reply #6 on: May 21, 2009, 02:18:47 PM »
Howdy folks. I am new to this forum and a new Samarui owner. I have been reading over the Haynes manual that came with the car and don't really understand what the O2 sensor does on the carbed models. All I get out of the book is to change it when the light comes on at 80K miles. I also can not find that switch, I guess I am lucky it is not on right now. Mike ???
Offline oak_raid
  • 193
« Reply #7 on: May 21, 2009, 03:51:55 PM »
The o2 sensor relays how much oxygen is in the exhaust to the ecm.  The ecm uses this info to adjust the fuel mixture in the carb.
Offline cmays03
  • 99
« Reply #8 on: May 21, 2009, 05:17:20 PM »
I dont know if its in the same place and my tracker but i found it next to the front left speaker pull the cover and the speaker and look to the right it should be right there. I just pulled my cluster and unplugged it.
95 geo tracker sas with dana 30,35 axles 3.55 gears, 33 tsl's, 3 and 4 link suspension. stock motor trans, tcase has 4.24:1 reduction kit.
Offline ack
  • 1659
    • Ack's FAQ
« Reply #9 on: May 28, 2009, 06:52:18 PM »
To clarify, the switch - on a Samurai - is inside the dash mounted next to the steering column. You have to stick your head under the dash and look up.  it is attached to three lengths of wire that are about a foot long.  These wires are attached to the back of the gage panel unit so it is not mounted very far below the dash panel.
Get your flashlight out...  ;D
Ack
