front axle nut
  • 2483 Views
Offline lowrider
  • 57
  • this is how the wife wants me to do it up
front axle nut
« on: December 21, 2008, 05:23:08 PM »
What size is the front axle nut size
Offline lowrider
  • 57
Re: front axle nut
« Reply #1 on: January 06, 2009, 06:59:47 PM »
So I guess nobody on here knows the front axle nut size. I need to repack my wheel bearings but the nuts on to tight can breck it with pliers.I need to know the size so I can buy a socket to fix the front end
Offline urbanwheeler
  • 696
Re: front axle nut
« Reply #3 on: January 06, 2009, 08:03:27 PM »
Samurai or sidekick?, if it is the sidekick, it has a "lock plate" of sorts that has 4 phillips head screws that thread into the actual lock nut. The lock nut itself has the 4 notches in it for the special socket to go into, or if you don't have one, a chisel will work as well. I cant remember if it is reverse threaded or not though. I should as I had mine apart enough times :P.
