1995 suzuki sidekick
  • 17 Replies
  • 6123 Views
Offline michael6189
  • 29
  • 1995 suzuki sidekick 4dr on 235/75/r15
« on: November 08, 2008, 09:52:33 AM »
hi im new at this i have a 1995 suzuki sidekick 5 spd 4dr and the rocker panels are rust out completely what is the best way  fix it ? ???
95 kick 4dr stock on 235/75/r15
Offline Praise Him
  • 256
Re: 1995 suzuki sidekick
« Reply #1 on: November 08, 2008, 10:23:14 AM »
Use the sure button ::)
sammy/toy axles/locked/geared/cased/36's
Offline michael6189
  • 29
« Reply #2 on: November 08, 2008, 10:44:35 AM »
Offline Lindenmooch
  • 560
« Reply #3 on: November 08, 2008, 12:56:18 PM »
 :laugh:
But for serious....Cut all not so good metal off....weld/rivet/screw/bolt new metal in.....bondo/POR-15/fiberglass/Great Stuff.
EZ.
Also.  Purchase new rocker panels.
Offline michael6189
  • 29
« Reply #4 on: November 08, 2008, 01:18:39 PM »
can i just use like square tubing to do it?
« Reply #5 on: November 08, 2008, 01:32:13 PM »
I replaced my rock panels with 2X4X1/8" rectangle tubes.  Mine were just starting to get bent up, so replaced them with something that does hold up.  The more rotted yours are, the more work it is to replace them.  It all depends on how far your are willing to go to fix it.
Of course the rock panels is only the start of what NEEDS to be done.  This is where replacing the rock panels got me.
 http://www.zukiworld.com/forum/index.php?topic=22395.0
Offline michael6189
  • 29
« Reply #6 on: November 08, 2008, 04:44:41 PM »
ok thanks that looks really good hope mine will look something like that  8)
« Reply #7 on: November 09, 2008, 06:27:49 AM »
 ??? Did he mean "search " button?
Offline urbanwheeler
  • 696
« Reply #8 on: November 09, 2008, 11:58:48 AM »
You mean the easy button :D
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #9 on: November 09, 2008, 01:19:32 PM »
This is your best option, it's easy, cheap & strong. Plus, I think it looks better, as well as raises the clearance level for a tighter rock rail(if wanted)
« Reply #10 on: November 09, 2008, 05:24:33 PM »
And it brings a smile on your face every time you drop it on a log or rock, or slide up against something unmovable and use the rail to walk around it.
The rails provide satisfaction every time I have been out.
Offline michael6189
  • 29
« Reply #11 on: November 09, 2008, 09:09:10 PM »
does any one know where i can get get some metal to use i cant seem to find any where around me that sells it ???
« Reply #12 on: November 10, 2008, 08:44:09 AM »
We are lucky enough to have a metal shop in the area that we can visit for things like that.  You can always order it, but it is usually 35 or more to have it shipped.  What town are you located in, there might be a fabrication shop nearby that has access to the 2x4 tubing.
If nothing else, most home hardware stores carry some metal.  They might have sizes you can use.
Offline michael6189
  • 29
« Reply #13 on: November 10, 2008, 04:14:41 PM »
im in rosemount mn and i checked at the hardware store and they only had 1x2
Offline jeff1997
  • 1228
  • 27
« Reply #14 on: November 10, 2008, 05:30:42 PM »
Go to a local fabrication or machine shop. They usually have a lot of stock on hand. We only have 4 employees and we probably have $100,000 in metal on hand at any given time.
3" Masterkit1 body lift
Custom strut spacers
