redline 1.3
  • 13 Replies
  • 3275 Views
Offline lowrider
  • 57
  • this is how the wife wants me to do it up
redline 1.3
« on: August 09, 2008, 06:16:54 PM »
I'm wanting to put a tach in my 86 samuri but I can't find anything on what the redline is on my 1.3 engine.
Offline ROSS
  • 1412
Re: redline 1.3
« Reply #1 on: August 09, 2008, 07:42:35 PM »
stock tach is 6500
Offline lowrider
  • 57
Re: redline 1.3
« Reply #2 on: August 10, 2008, 09:16:50 AM »
Thanks for the help
Offline lowrider
  • 57
Re: redline 1.3
« Reply #3 on: August 12, 2008, 05:01:13 AM »
Got my tach in. Notice that my motor is hard to wind it out to redline I only get to 5000.is this normal.does anyones make it to redline?
Offline rascott
  • 669
  • 15
Re: redline 1.3
« Reply #4 on: August 12, 2008, 05:30:43 AM »
i assumed "redline" was a theoretical rpm limit.
wind it up past that and things could scatter.
i will run |removethispart|@4000 rpm when climbing hills, slightly over sometimes when running the gears, but thats about it.
little motors have to be run up in order to keep up w/the big boys, but not because they like it.
just a thought.
mabe.
Offline 86badboy
  • 15
  • believe it!
Re: redline 1.3
« Reply #5 on: August 12, 2008, 07:00:46 AM »
when im drivng on the street my engine never sees anything less than 4000, primarily because of my gearing though.
BUILT NOT BOUGHT
86 sami, spoa, RUF w/ML's, 5.14 t-case, rear lockright, 33x12.5 mud T's, rear disk brakes, custom bumpers, custom lighting....list goes on.....
Blake
Offline lowrider
  • 57
Re: redline 1.3
« Reply #6 on: August 12, 2008, 07:56:19 AM »
When you run down the road at what rpm do you shift at
Offline Amilla
  • 1076
Re: redline 1.3
« Reply #7 on: August 12, 2008, 09:28:01 AM »
3000 to 3500 is my shift point if I'm just cursing, but it can go up from there....
Gears and tires really wiped out my high speed....
but thats they way i like it ;D
Amilla
Re: redline 1.3
« Reply #8 on: August 12, 2008, 04:00:26 PM »
It depends on my load & road conditions.
Offline 86badboy
  • 15
  • believe it!
Re: redline 1.3
« Reply #9 on: August 12, 2008, 05:42:53 PM »
normal conditions i shift at 3500 to 4000, if im toying off i hold it alot longer. i cruise at around 4300 in forth at 60 on the freeway.
BUILT NOT BOUGHT
Blake
Offline lowrider
  • 57
Re: redline 1.3
« Reply #10 on: August 12, 2008, 06:23:36 PM »
Cool I'm running and shifting bout right then.now all I need to do is adjust my valves so that ticking noise it has will quit. My dad never had it done when he had it
Offline SafetyGuy
  • 41
Re: redline 1.3
« Reply #11 on: August 12, 2008, 07:40:49 PM »
When adjusting valves, it is sometimes good not to get rid of the tick completely. When you here ticking, you know the valves are not to tight. Over tightening can cause burnt valves. Remember, a little ticking doesn't hurt.
If you Can Not Do It Safely, It's Not Worth Doing!
Offline lowrider
  • 57
Re: redline 1.3
« Reply #12 on: August 13, 2008, 04:34:44 PM »
Ok didn't know that about this engine. Thanks
Re: redline 1.3
« Reply #13 on: August 13, 2008, 06:45:44 PM »
Just adjust the valves to spec and don't worry whether they tick or not.  If they are adjusted correctly, they won't be too tight and burn valves.
