When swapping ring and pinion...
  • 10 Replies
  • 4109 Views
Offline OHIO_ZUKI
  • 53
« on: June 09, 2008, 09:25:51 PM »
I am considering swapping my 4.625's for a set of 5.12's. When/if I do this, are those the only items that I need to replace? Will the current, sleeves and bearing things work, or do I need everything from where the 5.12's came from?
i Kant sPel.
Offline Carnage
  • 2453
Re: When swapping ring and pinion...
« Reply #1 on: June 09, 2008, 09:42:38 PM »
dude, we've already asked you once to post in the right section
« Last Edit: June 10, 2008, 12:51:42 AM by Gen-Erix »
Offline OHIO_ZUKI
  • 53
« Reply #2 on: June 10, 2008, 05:34:42 PM »
Well is this not the Do It Yourself forum??? What forum should I post this is???
i Kant sPel.
Offline Amilla
  • 1076
« Reply #3 on: June 10, 2008, 06:24:24 PM »
I think they want you to put it in the "Suzuki Forum" section.
This section is for people that are building up there rigs, and for people showing how to make snorkels, and other things that can be done from your garage.
Amilla
Offline rascott
  • 669
  • 15
« Reply #4 on: June 10, 2008, 07:07:53 PM »
ohio-zuki
diy is a little misleading, huh.
it's clearer to me now- thanks amilla
richard
Offline Carnage
  • 2453
« Reply #5 on: June 10, 2008, 09:44:25 PM »
Amilla
that pretty much sums it up right there
as you posted a general "repair"
now if you did the gear swap and documented it with pictures and instructions
the How-To/DIY section is the place to be
Offline ZeusZuki
  • 411
« Reply #6 on: August 05, 2008, 09:26:25 PM »
http://www.zukiworld.com/forum/index.php?topic=21156.0
Look in here, might help you.
And yeah, wrong place dude  ;)
phloop
« Reply #7 on: August 06, 2008, 11:26:14 PM »
Don't worry about it OHIO_ZUKI , this place is a little confused itself. No A&E, no tech, no seperation of the generations so you kinda have to guess where to post your question.
Don't let these guys drag you down.
Offline bzzr2
  • 1011
« Reply #8 on: August 07, 2008, 12:30:20 PM »
why is this the wrong section?
09 taco reg cab short box 4x4
« Reply #9 on: August 07, 2008, 04:27:13 PM »
This is the right section.  Before it was in the Do It Yourself section, which is for project write-ups.
« Reply #10 on: August 07, 2008, 06:57:08 PM »
Just get complete thirds and swap them.  Much easier than swapping and setting up gears.
But if you want to swap and set up gears......yes, the bearings and crush sleeve is the same in the 5.12 and 4.62 thirds.  The only difference in 89-98 trackick 4.62 and 5.12 thirds is in 96 the front started using 26 spline axles and sidegears.
