frontend aligment 88 sammy
  • 2406 Views
« on: March 18, 2008, 08:28:30 PM »
i have 88 SAM and the front wheels are leaning in at top. it does not appear to have bent axletubes. can anyone explain how to adjust if possible.
Offline Amilla
  • 1076
Re: frontend aligment 88 sammy
« Reply #1 on: March 19, 2008, 09:56:06 AM »
Worn out knukle bearings is my guess, they are on the top and bottom of the knuckle.
Amilla
« Reply #2 on: March 27, 2008, 07:48:57 AM »
thanks for the input.other than replacing knuckle bearings is their any adjustment that could be made
Offline Amilla
  • 1076
« Reply #3 on: March 27, 2008, 09:18:07 AM »
You should check the wheel bearings before you dig into it all the way.
Just jack up the front of the car and grab the top of the tire and push and pull on it and see if there's any slop side to side.  If so your wheel bearings may need a lookin at.
Amilla
phloop
« Reply #4 on: March 27, 2008, 08:45:36 PM »
The next option is a bent front axle housing, but I think you would have figured that part out already.
