Factory gear ratio #2
  • 52 Replies
  • 10941 Views
BIG DOG
« on: December 03, 2007, 08:44:45 AM »
I posted this in the other factory gear ratio post but I thought it might be getting lost to people that have already looked at that post and one of them might have this info!
How about someone posting what year, engine ,tranny had what gears so we may have a better idea what to look for .And also what will fit in a sidekick/tracker or what won't.This is as close as I could come with the search,....posted by ZeusZuki ....Vits came out with 4.3 / 4.56 / 4.88 / 5.13 / 5.63 ratios stock ( again from memory   ) but most 1600's are 5.13.
Good luck.
ZeusZuki
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
Re: Factory gear ratio #2
« Reply #1 on: December 03, 2007, 09:11:58 AM »
5.13's came in 5 speeds,
5.63 only came on 1989 1.3 carbed Sidekicks,
5.38 came on early 4 door 5 speeds 91-95,
4.63 came on 89-94 3 speed automatics,
4.30 came on 92-95 4 speed automatics
4.88 came on 99-03 automatic Grand Vitara's
Some of the other gear ratios are are available in second generation Vits as well.
http://Car-Part.com makes a great parts interchange guide. just look at the part you want then click years at the top of the listing, all the years that fit will be listed in order.
Student of Now Master of Then
Offline SnoFalls
  • 1358
« Reply #2 on: December 03, 2007, 11:00:30 AM »
I'm questinging this
doesn;t jive with
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #3 on: December 03, 2007, 12:20:40 PM »
I can add that all X-90's regardless of 5 speed or auto came factory with 4.62's(or 4.63's depending on how you round numbers... LOL!)
  • 416
  • Lil Suzys Dad
« Reply #4 on: December 03, 2007, 01:00:33 PM »
doesn;t jive with
512's came in 2 doors.
« Reply #5 on: December 03, 2007, 01:57:07 PM »
The 4.30 ratio only came in the 16v auto 3speed, 1995, I think.
Offline SnoFalls
  • 1358
« Reply #6 on: December 03, 2007, 01:59:57 PM »
doesn;t jive with
The correct answer is 5.38's only came in '91 4dr manuals.
« Reply #7 on: December 03, 2007, 02:12:16 PM »
doesn;t jive with
Because in 91 the 4 door manuals were 8 valve motors.  In 92 they went to 16 valves and the 5.12gears.
Offline flexmonger
  • 209
  • live to wheel and wheel to die.
« Reply #8 on: December 03, 2007, 08:00:10 PM »
doesn;t jive with
   Actually afore mentioned is right but 5:38's were offered for more than just one year. It may have been offered more to the california models for a longer time span.
Offline goodyz
  • 133
  • Turdzuki.
« Reply #9 on: December 03, 2007, 11:08:24 PM »
I hate to throw a wrench in the info stated already (which was mostly correct) but I have a '95 4 door 4 speed auto that came with 5.12's. And the '91 4 door 8 valves manual trans I can conform at 5.38 as I have pulled diffs out of 2 different trucks and that's what the ratio was.
-goodyz
« Reply #10 on: December 04, 2007, 06:16:26 AM »
My info applies only to 89-98 trackicks.....99+ trackicks may or may not be different.
The 4.30 ratio came in any trackick with the 16V and a 3 speed auto.
5.38s ONLY came in the 91, 4 doors, with a 5 speed......all 91 4 doors came with the 8V engine.
« Last Edit: December 04, 2007, 06:29:13 AM by Skyhiranger »
« Reply #11 on: December 04, 2007, 07:55:06 AM »
What other years had the 16v and 3 speed auto? I thought they went to 4 speed after that.
« Reply #12 on: December 04, 2007, 08:05:03 AM »
Here is a list.....it is simply designed to tell you what ratio you have based on year, body, engine, and tranny.
89-98 Trackick gear ratios
Year   2 or 4 door  Engine type   Transmission   Axle ratio
89        2              1.3L carb.       5 speed man.   5.625
89-95   2              1.6L TBI         5 speed man.   5.125
89-95   2              1.6L TBI         3 speed auto   4.625 (a 94/95 may have 4.30s)
91        4              1.6L TBI         5 speed man.   5.375
91       4              1.6L TBI          3 speed auto     4.625
92-98   4              1.6L MPFI       5 speed man.   5.125
92-98   4              1.6L MPFI       3 speed auto   4.30 combo never offered
92-98   4              1.6L MPFI       4 speed auto   5.125
94-98   2              1.6L MPFI       5 speed man.   5.125
94-98   2              1.6L MPFI       3 speed auto   4.30
94-98   2              1.6L MPFI       4 speed auto   5.125 combo never offered
96-98   X90          1.6L MPFI       auto or man.   4.625
4.625 gears have an 8/37 tooth count
4.30 gears have a 10/43 tooth count
5.125 gears have an 8/41 tooth count
5.375 gears have an 8/43 tooth count
5.625 gears have an 8/45 tooth count
« Last Edit: November 19, 2008, 06:13:30 AM by Skyhiranger »
« Reply #13 on: December 04, 2007, 08:14:04 AM »
I think that the 3 speed was available with the 16V up until 98 at least.  I am 99% sure that it was not a 95 only option....edit: in fact I know it wasn't, because I have seen a 96 2 door with a 3 speed auto.
Offline goodyz
  • 133
  • Turdzuki.
« Reply #14 on: December 04, 2007, 08:18:10 AM »
Now that is a nice comprehensive list! I'm printing that one and putting it in my turdzuki file.
-goodyz
