My little sammy project
  • 21 Replies
  • 7113 Views
Offline Ddog87
  • 109
« on: May 08, 2007, 10:15:32 AM »
This started off the be a K.I.S.S. project (keep it simple stupid) but...... things went a little over board. Run down of parts. Sammy frame, sky's wrangler swap, SPRING UNDER, toy axles, rear e-locker front lock right, 4.10 gears, 6.4:1 t-case 34x10.5x15 LTB swampers, toy high steer, rebuilt front axle with longfields, TLC vented rotors,v6 calipers, gusseted front housing. 99 Tracker 16 valve motor with 2wd tranny. Flexed pic has 21" under tire before lifting the other front tire rear was not even close to coming up yet. Building this to drive to the local trails instead of trailering, (that gets old) Hope to have the drivetrain in in the next cuople weeks. Then the body.
kingzoo
Re: My little sammy project
« Reply #1 on: May 08, 2007, 11:56:13 AM »
    I HAVE  HAD PEOPLE LAUGH THEIR ASS OFF AND TELL ME I WAS CRAZY FOR PULLING THE BODY FOR A MAJOR PROJECT.SILLY THEM!IT MAKES THE JOB A LOT EASIER,ESPECIALLY SUSPENSION WORK,AND LETS YOU SEE EVERYTHING PERFECTLY WHILE DOING THE KOB.LOOKS GOOD,AND ONE DAY MABEY I WILL HOOK MY SIDEKICK UP LIKE THAT.LOVE THE YOTA SWAPS.
Offline Ddog87
  • 109
« Reply #2 on: May 08, 2007, 01:36:01 PM »
Mine was already apart when I started, which made it easier
kingzoo
« Reply #3 on: May 08, 2007, 06:47:50 PM »
  IT CERTAINLY DOES MAKE THINGS EASIER WHEN THEY ARE ALREADY APART.I CURRENTLY HAVE MY  911 IN MORE PIECES THAN PORSCHE EVER INTENDED.
Offline locjaw
  • 2045
  • 22
« Reply #4 on: May 09, 2007, 07:39:53 AM »
i think the estimate is gonna come in a little high ;D ;D ;D
jason
Offline Ddog87
  • 109
« Reply #5 on: May 09, 2007, 08:23:32 AM »
Ya I was cracking up after I posted the pic and wondered if anybody else would notice, LOL
kingzoo
« Reply #6 on: May 09, 2007, 11:21:29 AM »
  i agree.estimate night be a little steep!how much body lift are you gonna use?
Offline Ddog87
  • 109
« Reply #7 on: May 09, 2007, 01:09:52 PM »
Probably just a one inch to help clear the motor, everthing else will be cut to fit
Offline Ddog87
  • 109
« Reply #8 on: September 06, 2007, 08:51:50 AM »
Man this project is taking forever  ::) but it RUNS!!!! I was also able to use the gas tank out of the 99 tracker Looks like I will have more clearance between the tank and the axle also. And the nice thing is is it has ALL of the right wire harness plugs.
Offline j2custom
  • 197
  • Suzuki's rule!
« Reply #9 on: September 06, 2007, 04:59:24 PM »
Nice job.  Keep up the pics.   8)
2001 Chevy Tracker 4 door 2.0 5 spd 4x4
1995 Geo Tracker 1.6 8V 5 spd 4x4
2005 Tundra Crew Cab Limited 4x4
 It's not what you buy... it's what you build
« Reply #10 on: September 06, 2007, 05:51:19 PM »
I keep trying to get my neighbor to roll his 99 tracker so I can get me one of those crummy engines for mine. can you slide a piece of pipe into the rear of the frame or is the tank going to be too close?
Offline Ddog87
  • 109
« Reply #11 on: November 13, 2007, 01:17:52 PM »
MORE PROGRESS
TANK MOUNTED
BODY ON
FLEX
TIRE CONTACT IN REAR
ALL THAT NEEDED CUT TO CLEAR
Offline Carnage
  • 2453
« Reply #12 on: November 13, 2007, 02:25:15 PM »
lookin good
you gonna take the body off and spray the frame down?
Offline Ddog87
  • 109
« Reply #13 on: November 13, 2007, 03:10:01 PM »
I am going overboard on this one.  ??? I plan on sand blasting the frame and tub, then paint
Offline Carnage
  • 2453
« Reply #14 on: November 13, 2007, 03:23:07 PM »
wow... should look great
cant wait for the pics
