Does it look like it will still work if the gas tank was lifted?
I am wondering the same thing. I planned on lifting my tank. I have to fix the rotted out crossmember first. How much did it run you?
it will work with a tank lift.You will have to grind some of the top lip on the skid plate to fit around the square thing in the x member or just cut that x member out and put in a new one
