Gearing Chart for what Tire Size with what DriveTrain Components
  • 8017 Views
Offline kozaz
  • 168
The following forumulas calculate what Tire Size is recommended for a Tracker with Specific Drivetrain Components, such as Auto Trans, 5 speed Manual Trans, Ring and Pinion, Stock Tracker Transfer Case, and Stock Samurai Transfer Case installed in place of a Tracker Transfer Case.
Please keep in mind these calculations are for HIGH RANGE ONLY!  If you have a Rock Crawler Gear Set in the Samurai Transfer Case, the Tire Size will not be reflected correctley in the forumulas below due to the higher HIGH Range Ratio. (Stock Samurai Transfer Case HIGH Range Ratio is 1.409:1)
The Tracker Transfer case (So far) can not have it's HIGH Range Ratio Modified.  Currently ALL Rock Crawler Gear Sets for the Tracker Transfer Cae have the Stock 1:1 HIGH Ratio.
With out further due, Enjoy....
Tire Size Recomedation for Tracker with Following Drivetrain:
Transmission     = Auto
Transfer Case    = Stock (Tracker T-Case HIGH Range = 1:1)
Ring and Pinion  = 4.62 (Stock Gears for Auto Trans)
                            NOTE
Calculations are for HIGH Range Gearing.
EXAMPLE
(Tracker CALMIMI gears / Tracker Stock Tires / Tracker Auto-Trans 4.62 Gears)
5.83 (clamini gears) X 27" (stock tire size) / 4.62 (stock r&p's) = 34.071
5.83 Ring and Pinion good for 34" tires with an auto tranny!
End of EXAMPLE
4.30 X 27 / 4.62 = 25.12 Tall Tires   (Tracker / Toyota Gears Non overdrive 2dr auto 1.6L 16v Gears)
4.56 X 27 / 4.62 = 26.649 Tall Tires (Toyota Gears)
4.62 X 27 / 4.62 = 27 Tall Tires        (Tracker Gears 2dr auto 1.6L 8v Gears)
4.71 X 27 / 4.62 = 27.525 Tall Tires (Ford 9" Gears)
4.84 X 27 / 4.62 = 28.285 Tall Tires (Ford 9" Gears)
4.86 X 27 / 4.62 = 28.402 Tall Tires (Ford 9" Gears)
4.88 X 27 / 4.62 = 28.519 Tall Tires (Toyota / Grand Vitara  Gears)
5.00 X 27 / 4.62 = 29.220 Tall Tires (Ford 9" Gears)
5.12 X 27 / 4.62 = 29.922 Tall Tires (Tracker / XL-7 Gears Most all 4dr's (Non Vitara) *  Most all 5-speed Track Kick's * Most all Autos with overdrive Gears)
5.14 X 27 / 4.62 = 30.038 Tall Tires (Ford 9" Gears)
5.29 X 27 / 4.62 = 30.915 Tall Tires (Toyota / Ford Gears)
5.37 X 27 / 4.62 = 31.383 Tall Tires (Ford 9" Gears)
5.38 X 27 / 4.62 = 31.441 Tall Tires (Tracker Gears Early model 1.6L 8v 4dr 5-spd Track Kick's (RARE) Gears)
5.43 X 27 / 4.62 = 31.733 Tall Tires (Ford 9" Gears)
5.50 X 27 / 4.62 = 32.142 Tall Tires (Ford 9" Gears)
5.57 X 27 / 4.62 = 32.552 Tall Tires (Ford 9" Gears)
5.63 X 27 / 4.62 = 32.902 Tall Tires (Tracker Gears Early 1988-1989 1.3L powered Track Kick (RARE) Gears)
5.67 X 27 / 4.62 = 33.136 Tall Tires (Ford 9" Gears)
5.71 X 27 / 4.62 = 33.370 Tall Tires (Toyota Gears)
5.83 X 27 / 4.62 = 34.071 Tall Tires (Tracker CALMINI / Ford 9" Gears)
6.00 X 27 / 4.62 = 35.065 Tall Tires (Ford 9" Gears)
6.14 X 27 / 4.62 = 35.883 Tall Tires (Ford 9" Gears)
6.20  X 27 / 4.62 = 36.234 Tall Tires (Ford 9" Gears)
6.33 X 27 / 4.62 = 36.993 Tall Tires  (Ford 9" Gears)
6.50 X 27 / 4.62 = 37.987 Tall Tires  (Ford 9" Gears)
6.66 X 27 / 4.62 = 38.922 Tall Tires  (Ford 9" Gears)
7.00 X 27 / 4.62 = 40.909 Tall Tires  (Ford 9" Gears)
7.16 X 27 / 4.62 = 41.844 Tall Tires  (Ford 9" Gears)
7.33  X 27 / 4.62 = 42.837 Tall Tires  (Ford 9" Gears)
Transmission     = 5 Speed Manual
Ring and Pinion  = 5.12 (Stock Gears for 5 Speed Manual Trans)
                            NOTE
EXAMPLE
(Tracker CALMIN gears / Tracker Stock Tires / Tracker Manual-Trans 5.12 Gears)
5.83 (clamini gears) X 27" (stock tire size) / 5.12 (stock r&p's) = 30.74
5.83 Ring and Pinion good for 30-31" tires with a manual tranny!
End of EXAMPLE
4.30 X 27 / 5.12 = 22.67 Tall Tires   (Tracker / Toyota Gears Non overdrive 2dr auto 1.6L 16v Gears)
4.56 X 27 / 5.12 = 24.046 Tall Tires (Toyota Gears)
4.62 X 27 / 5.12 = 24.36 Tall Tires   (Tracker Gears 2dr auto 1.6L 8v Gears)
4.88 X 27 / 5.12 = 25.734 Tall Tires (Toyota / Grand Vitara  Gears)
5.00 X 27 / 5.12 = 26.367 Tall Tires  (Ford 9" Gears)
5.12 X 27 / 5.12 = 27 Tall Tires        (Tracker / XL-7 Gears Most all 4dr's (Non Vitara) *  Most all 5-speed Track Kick's * Most all Autos with overdrive Gears)
5.14 X 27 / 5.12 = 27.105 Tall Tires  (Ford 9" Gears)
5.29 X 27 / 5.12 = 27.896 Tall Tires  (Ford 9" Gears)
5.37 X 27 / 5.12 = 28.318 Tall Tires  (Ford 9" Gears)
5.38 X 27 / 5.12 = 28.371 Tall Tires (Tracker Gears Early model 1.6L 8v 4dr 5-spd Track Kick's (RARE) Gears)
5.43 X 27 / 5.12 = 28.634 Tall Tires  (Ford 9" Gears)
5.50 X 27 / 5.12 = 29.003 Tall Tires  (Ford 9" Gears)
5.57 X 27 / 5.12 = 29.373 Tall Tires  (Ford 9" Gears)
5.63 X 27 / 5.12 = 29.689 Tall Tires (Tracker Gears Early 1988-1989 1.3L powered Track Kick (RARE) Gears)
5.67 X 27 / 5.12 = 29.900 Tall Tires  (Ford 9" Gears)
5.71 X 27 / 5.12 = 30.111 Tall Tires (Toyota Gears)
5.83 X 27 / 5.12 = 30.744 Tall Tires (Tracker CALMINI / Ford 9" Gears)
6.00 X 27 / 5.12 = 31.640 Tall Tires  (Ford 9" Gears)
6.14 X 27 / 5.12 = 32.379 Tall Tires  (Ford 9" Gears)
6.20 X 27 / 5.12 = 32.695 Tall Tires  (Ford 9" Gears)
6.33 X 27 / 5.12 = 33.380 Tall Tires  (Ford 9" Gears)
6.50 X 27 / 5.12 = 34.277 Tall Tires  (Ford 9" Gears)
6.66 X 27 / 5.12 = 35.121 Tall Tires  (Ford 9" Gears)
7.00 X 27 / 5.12 = 36.914 Tall Tires  (Ford 9" Gears)
7.16 X 27 / 5.12 = 37.758 Tall Tires  (Ford 9" Gears)
7.33  X 27 / 5.12 = 38.654 Tall Tires  (Ford 9" Gears)
Transmission     = Auto / 5 Speed Manual
Transfer Case    = Stock Samurai T-Case in place of Tracker T-Case (Samurai T-Case HIGH Range = 1.409:1)
Ring and Pinion  = 4.62 (Stock Gears for Auto Trans) / 5.12 (Stock Gears for 5 Speed Manual Trans)
                            NOTE
EXAMPLE
(Tracker gears / Samurai T-Case High Range / Tracker Stock Tires / Tracker Manual-Trans 5.12 Gears or Tracker Auto Trans 4.62 Gears)
4.30 (Tracker Gears) X 1.409 (Sammy T-Case Stock High Range) = 6.059
27 (stock kick tire) X 6.059 = 163.585
163.585 / 5.12   (Stock Manual Tranny Tracker Gears) = 31.950 Tall Tires
163.585 / 4.62   (Stock Auto Tranny Tracker Gears) = 35.408 Tall Tires
4.30 Ring and Pinion good  for 31" tires with a manual tranny, and 35" tires with an auto tranny!
End of EXAMPLE
3.90 (Toyota (REAR 8 inch only) Gears) X 1.409 (Samurai T-Case Stock High Range) = 5.4951
27 X 5.7769 = 148.3677
148.3677 / 5.12   (Stock Manual Tranny Tracker Gears) = 28.978 Tall Tires
148.3677 / 4.62   (Stock Auto Tranny Tracker Gears) = 32.114 Tall Tires
4.10 (Grand Vitara  / Toyota Gears) X 1.409 (Samurai T-Case Stock High Range) = 5.7769
27 X 5.7769 = 155.9763
155.9763 / 5.12   (Stock Manual Tranny Tracker Gears) = 30.464 Tall Tires
155.9763 / 4.62   (Stock Auto Tranny Tracker Gears) = 33.761 Tall Tires
4.11 (Ford 9" Gears) X 1.409 (Samurai T-Case Stock High Range) = 5.79099
27 X 5.79099 = 156.35673
156.35673 / 5.12   (Stock Manual Tranny Tracker Gears) = 30.538 Tall Tires
156.35673 / 4.62   (Stock Auto Tranny Tracker Gears) = 33.843 Tall Tires
4.29 (Ford 9" Gears) X 1.409 (Samurai T-Case Stock High Range) = 5.7769
27 X 5.7769 = 163.20447
163.20447 / 5.12   (Stock Manual Tranny Tracker Gears) = 31.875 Tall Tires
163.20447 / 4.62   (Stock Auto Tranny Tracker Gears) = 35.325 Tall Tires
4.30 (Tracker / Toyota Gears) X 1.409 (Samurai T-Case Stock High Range) = 6.04461
27 X 6.04461 = 163.5849
163.5849 / 5.12   (Stock Manual Tranny Tracker Gears) = 31.950 Tall Tires
163.5849 / 4.62   (Stock Auto Tranny Tracker Gears) = 35.407 Tall Tires
4.56 (Toyota Gears) X 1.409 (Samurai T-Case Stock High Range) = 6.425
27 X 6.425 = 173.475
173.475 / 5.12  (Stock Manual Tranny Tracker Gears) = 33.88 Tall Tires
173.475 / 4.62  (Stock Auto Tranny Tracker Gears) = 37.548 Tall Tires
4.57  (Ford 9" Gears) X 1.409 (Samurai T-Case Stock High Range) = 6.43913
27 X 6.43913 = 173.82651
173.82651 / 5.12   (Stock Manual Tranny Tracker Gears) = 33.956 Tall Tires
173.82651 / 4.62   (Stock Auto Tranny Tracker Gears= 37.624 Tall Tires
4.62 (Tracker Gears) X 1.409 (Samurai T-Case Stock High Range) = 6.50958
27 X 6.50958 = 175.75866
175.75866 / 5.12   (Stock Manual Tranny Tracker Gears) = 34.327 Tall Tires
175.75866 / 4.62   (Stock Auto Tranny Tracker Gears) = 38.073 Tall Tires
4.71 (Ford 9" Gears) X 1.409 (Samurai T-Case Stock High Range) = 6.63639
27 X 6.63639 = 179.18253
179.18253 / 5.12   (Stock Manual Tranny Tracker Gears) = 34.996 Tall Tires
179.18253 / 4.62   (Stock Auto Tranny Tracker Gears) = 38.784 Tall Tires
4.84 (Ford 9" Gears) X 1.409 (Samurai T-Case Stock High Range) = 6.81956
27 X 6.81956 = 184.12812
184.12812 / 5.12   (Stock Manual Tranny Tracker Gears) = 35.962 Tall Tires
184.12812 / 4.62   (Stock Auto Tranny Tracker Gears) = 39.866 Tall Tires
4.86 (Ford 9" Gears) X 1.409 (Samurai T-Case Stock High Range) = 6.84774
27 X 6.84774 = 184.888
184.888 / 5.12   (Stock Manual Tranny Tracker Gears) = 36.111 Tall Tires
184.888 / 4.62   (Stock Auto Tranny Tracker Gears) = 40.019 Tall Tires
4.88 (Grand Vitara  / Toyota Gears) X 1.409 (Samurai T-Case Stock High Range) = 6.87592
27 X 6.87592 = 185.64984
185.64984 / 5.12   (Stock Manual Tranny Tracker Gears) = 36.259 Tall Tires
185.64984 / 4.62   (Stock Auto Tranny Tracker Gears) = 40.183 Tall Tires
5.00 (Ford 9" Gears) X 1.409 (Samurai T-Case Stock High Range) = 7.045
27 X 7.045 = 190.215
190.215 / 5.12  (Stock Manual Tranny Tracker Gears) = 37.151 Tall Tires
190.215 / 4.62  (Stock Auto Tranny Tracker Gears) = 41.172 Tall Tires
5.12 (Tracker / XL-7 Gears) X 1.409 (Samurai T-Case Stock High Range) = 7.21408
27 X 7.21408 = 194.78016
194.78016 / 5.12 (Stock Manual Tranny Tracker Gears) = 38.043 Tall Tires
194.78016 / 4.62 (Stock Auto Tranny Tracker Gears) = 42.16 Tall Tires
5.14 (Ford 9" Gears) X 1.409 (Samurai T-Case Stock High Range) = 7.242
27 X 7.242 = 195.54102
195.54102 / 5.12  (Stock Manual Tranny Tracker Gears= 38.191 Tall Tires
195.54102 / 4.62  (Stock Auto Tranny Tracker Gears) = 42.324 Tall Tires
5.29 (Toyota / Ford 9" Gears) X 1.409 (Samurai T-Case Stock High Range) = 7.45
27 X 7.45= 201.24
201.24 / 5.12  (Stock Manual Tranny Tracker Gears) = 39.304 Tall Tires
201.24 / 4.62  (Stock Auto Tranny Tracker Gears) = 43.558 Tall Tires
5.37 (Ford 9" Gears) X 1.409 (Samurai T-Case Stock High Range) = 7.56633
27 X 7.56633 = 204.29091
204.29091 / 5.12  (Stock Manual Tranny Tracker Gears) = 39.900 Tall Tires
204.29091 / 4.62  (Stock Auto Tranny Tracker Gears) = 44.218 Tall Tires
5.71 (Toyota Gears) X 1.409 (Samurai T-Case Stock High Range) = 8.04539
27 X 8.04539 = 217.22553
217.22553 / 5.12 =  (Stock Manual Tranny Tracker Gears) = 42.426 Tall Tires
217.2255 3/ 4.62 =  (Stock Auto Tranny Tracker Gears) = 47.018 Tall Tires
5.83 (Tracker CALMINI / Ford 9" Gears) X 1.409 (Samurai T-Case Stock High Range) = 8.21447
27 X 8.21447 = 221.79069
221.79069 / 5.12 (Stock Manual Tranny Tracker Gears) = 43.318 Tall Tires
221.79069 / 4.62 (Stock Auto Tranny Tracker Gears) = 48.006 Tall Tires
Tracker 5 Speed Manual Transmission /T ransfer Case / Ring & Pinion Gearing Ratios
Gear ratios
   1st 3.65
   2nd 1.95
   3rd 1.38
   4th 1.00
   5th 0.86
   Reverse 3.67
Transfer gear ratios
   Low (4WD) 1.82
   High 1.00
Differential ratio 5.12
Tracker 3 Speed Automatic Transmission / Transfer Case / Ring & Pinion Gearing Ratios
Gear ratios
   1st 2.40
   2nd 1.47
   3rd 1.00
   4th NA
   Reverse 2.00
   Low (4WD) 1.82
   High 1.00
Differential ratio 4.62
Sidekick 5 Speed Manual Transmission / Transfer Case / Ring & Pinion Gearing Ratios
Manual Transmission
Type Five-speed, all synchromesh
Clutch Dry, single disc, diaphragm spring
Gear ratios
   1st 3.652
   2nd 1.947
   3rd 1.379
   4th 1.000
   5th 0.795
   Reverse 3.670
   Low (4WD) 1.816
   High 1.000
Differential ratio 5.125
Sidekick 4 Speed Automatic Transmission / Transfer Case / Ring & Pinion Gearing Ratios
Type Four-speed automatic with overdrive
Torque Converter Lock-up
Gear ratios
   1st 2.826
   2nd 1.493
   3rd 1.000
   4th 0.730
   Reverse 2.703
   Low (4WD) 1.816
   High 1.000
Samurai Manual Transmission / Transfer Case / Ring & Pinion Gearing Ratios
Manual Transmission
Gear ratios
   1st 3.652
   2nd 1.947
   3rd 1.423
   4th 1.000
   5th 0.795
   Reverse 3.466
      Low (4WD) 2.268
      High 1.409
Differential ratio 3.73
The following info is a repesentation of other Gear Ratios in other types of axles, some are not used, but should answer any questions about what type of gears are available in other types of axles if the need should occur.
MISC. AVAILABLE GEAR RATIO INFO
Toyota 79-85 Solid Front 8"   3.90 4.10, 4.30 4.38
Toyota 79-85 Solid Front 8"   3.90 4.10, 4.30 4.38    (4.38s only in 1980, 3.90 only in 1981  8" Drums)
Toyota 86-95 IFS Front 7.5"  4.10 4.30, 4.56, 4.88  (4.10s Manual Trans, 4.30s Auto Trans)
Toyota 86-95 Solid Rear 8"   4.10 4.30, 4.56, 4.88
Toyota 7.5" and 8" Ring Pinions   5.29 and 5.71  (Aftermarket)
Ford 9"     4.11, 4.29, 4.57, 4.71, 4.84,  4.86, 5.00, 5.14, 5.29, 5.37, 5.43, 5.50, 5.57, 5.67, 5.83, 6.00, 6.14, 6.20, 6.33, 6.50, 6.66, 7.00, 7.16, 7.33
Tracker 4.30, 4.62, 4.89, 5.12, 5.83
Grand Vitara  4.10, 4.88
XL-7  5.12 (Both Auto and Manual Trans)
GM 7.25 IFS  4.11, 4.56
GM 8.25 IFS  4.11, 4.56, 4.88, 5.13
GM 9.25 IFS  4.11, 4.56
The following is from Randy's Ring and Pinion.
DANA 44
YG D44-411 D44 4.09 R&P Dana D44 4.09
YG D44-427 D44 4.27 R&P Dana D44 4.27
YG D44-456 D44 4.55 R&P Dana D44 4.55
YG D44-456T D44 4.56 THICK R&P ONLY (FITS_3.73_CSE) Dana D44 4.56
YG D44-488 D44 4.89 R&P Dana D44 4.89
YG D44-488T D44 4.88 THICK R&P ONLY(FITS_3.73_CSE) NOT_RUBICON!!! Dana D44 4.88
YG D44-488T-RUB D44 4.88 THICK R&P FITS RUBICON Dana D44 4.88
YG D44-513 D44 5.13 R&P Dana D44 5.13
YG D44-538 D44 5.38 R&P Dana D44 5.38
YG D44-589 D44 5.89 R&P Dana D44 5.89
DANA 60
YG D60-456 D60 4.56 R&P Dana D60 4.56
YG D60-488 D60 4.88 R&P Dana D60 4.88
YG D60-513 D60 5.13 R&P Dana D60 5.13
YG D60-538 D60 5.38 R&P Dana D60 5.38
YG D60-586 D60 5.86 R&P Dana D60 5.86
YG D60-617 D60 6.17 R&P Dana D60 6.17
YG D60-717 D60 7.17 R&P Dana D60 7.17
If you see any Problems with this info please let me know and I will keep it up to date as possible!
Ryan (KozAZ)
« Last Edit: March 22, 2006, 06:42:09 AM by kozaz »
Offline kozaz
  • 168
Re: Gearing Chart for what Tire Size with what DriveTrain Components
« Reply #1 on: March 21, 2006, 01:26:15 PM »
This helped me decide to go with the following for my 97 Tracker. (Until I change my mind again)  ::)
Trans = Auto
Front 3rd  = Toyota IFS 3rd with 4.10 Ring and Pinion
Rear Axle  = Toyota Axle with 4.10 Ring and Pinion
Transfer Case = Stock Samurai (Kicker 1)
155.9763 / 5.12   (Stock Manual Tranny Tracker Gears) = 30.464 Size Tires
155.9763 / 4.62   (Stock Auto Tranny Tracker Gears) = 33.761 Size Tires
The best part is, that the Toyota Rear axle is 58.5" wide (86-95 trucks/4runners), and I already have IFS 7.5 Toyota Diff.  :)
Another plus, is I could keep my current 5 speed and wheel with 30x9.5x15s.  Then when I ready to jump up to 32's or 33's, I just have to replace the 5spd with an Auto.
This will hopefully require a lot less fab work instead of installing a Ford 9".  Plus, the Toyota stuff will be a great upgrade for strength and can easily handle 35's.  Just have to figure out how I'm going to link up the Toyota Rear.
Or, after the Toyota Rear is installed, I could just install the Vitara 3rd and it would not required any mods in the front.  Only thing is, then I'm limited to 4.10 or 4.88 Ring and Pinions.  Making the front and rear diffs both Toyota, would allow me to at least have 4.10, 4.30, 4.56, 4.88, 5.29, and 5.71 Ring and Pinion options.
Or... I could just swap in the Vitara 4.10s,  I guess that would be the easiest!  :-[
« Last Edit: March 21, 2006, 06:27:28 PM by kozaz »
