a: you rock for posting the safe disabling procedure.
b: i'd really like to know a good way to wire in a disabling switch.
c: i guess the easy way would be to wire it in with a 90 second "wait for it....." requirement, huh?
a: Thank Jerry (jtgh) who, like the venerable ack, does alot for the community. HUGE THANKS to both for thier sites!!
jtgh's site has moved, it's now here:
http://www.kick-fix.com/It's in the FSM, no reason it should be secret, but ofc this is just for disabling while working on the vehicle to avoid accidental (& expensive & dangerous) discharge.
Myself personally I don't trust gen 1 airbags much. I'm a little guy, & the damned things are just as likely to injure me as help in an accident, they're designed for a 5'9" 180lb dummy... & I'm not 1 of those. This is why there are gen 2 airbags now... they deploy with much less force.
b & c: There's been call for this for a long time, but I doubt manufacturers will do it for liability reasons... Could it be done? Prolly... trouble is the sensors have no idea if you just rammed a rock offroad at xx mph, or just got hit by a truck at xx mph onroad. There's also the problem of remembering to switch it back on when you go back on the road...
i was like 3 rigs back and we thought someone had fired a shotgun! i wouldnt recommend disconnecting them because it's aginst the law. that being said, i prolly wouldnt drive a rig off road unless it didnt have working airbags
No doubt, basically it
is a shotgun, only replace the gunpowder with air & put a poofy bag over the barrel.
I think it has something to do with his after market bumpers. Another person we know has been wheeling a newer tracker for a few years with no issue. Maybe it transmits more of a jolt? Yes Jason I know Gayle has Poohbuilt bumpers now, I think she used to wheel it harder than she does now.
Yeah, could well be cuz of stiff bumpers, after all the factory bumpers are squishy for the 5mph crumple req., which isn't a bad thing really since the jolt has to go somewhere, if the bumper doesn't absorb it... it moves inward. From what I gather, the trigger is a ball bearing in a tube with a ramp. If impact is enough to throw the ball over the ramp, it hits the contacts & BOOM, airbags deployed.
Ofc, I'm not recommending anyone disable their airbags, YMMV.
Fuzz
