NEW FRONT STRUTS TRACKER/SIDEKICK
  • 121 Replies
  • 39192 Views
Offline kreator
  • 634
  • 15
« on: December 27, 2011, 10:39:53 AM »
All new front strut lift shocks have been developed and testing is about complete and production will start next week . The struts are fox coil air shock base that has been modified for the the front end .there is some mods required and all parts will be supplied .
The advantage of this design is that you have three ways of adjusting the struts for desired ride height and softness of the ride , 1 / nitrogen pressure , 2 / top coil spring and 3 / bottom coil spring . The shock/strut has the ability of valve adjusting for compression and rebound .
One more thing that makes nice is that they are REBUILDABLE .
PICS AND PRICES TO BE AVAILABLE SOON.
Offline DonD
  • 140
Re: NEW FRONT STRUTS TRACKER/SIDEKICK
« Reply #1 on: December 27, 2011, 11:41:40 AM »
Excellent !
Central AZ
'90 Tracker
8k Smitty Winch
Man. hubs
Skids
Nerfs and sliders
Lockrite rear
OME susp
4.24 TC
ZOR Ft Bumper
« Reply #2 on: December 27, 2011, 03:29:33 PM »
Looking forward to seeing them. Alternitives to the Big 2  ( OME/Bilstein) are always a good thing.
Offline kreator
  • 634
  • 15
« Reply #3 on: December 29, 2011, 02:30:22 PM »
HERE ARE SOME PICS OF THE NEW LONG TRAVEL FRONT STRUTS
  • 4320
  • 167
« Reply #4 on: December 29, 2011, 05:09:16 PM »
Is there a bearing in there somewhere or does the steering depend on the strut/shock piston rod rotating within the body of the strut/shock?
Offline kreator
  • 634
  • 15
« Reply #5 on: December 29, 2011, 05:20:36 PM »
the shocks have bushings in them and can turn freeley
Offline swanson
  • 55
  • 89 chevy tracker
« Reply #6 on: December 29, 2011, 07:15:44 PM »
wow these look awesome! how much will they run? i might have to get a set when you start selling them.
« Reply #7 on: December 30, 2011, 12:30:50 AM »
Do we need to run the Brace from one strut to the other?  Further spec's and price would be nice.
I hope these are available soon, because new struts are part of the plans for present upgrades.
« Reply #8 on: December 30, 2011, 04:33:02 AM »
Do these eliminate the standard coils in favor of coil overs? If so I imagine various rates are available? I already have a strut brace, do we need to purchase yours as part of the kit? Price?
Offline Jebers53
  • 1996 Tracker
« Reply #9 on: December 30, 2011, 05:55:30 AM »
X2
1996 Geo Tracker 4x4 5 speed manual 2 inch Jeff spacer lift 235/75/15 BFG AT
ZOR front bumper/stinger
2008 Provan Tiger Camper 4x4 on Chevy 3500 HD Duramax/Allison
Offline kreator
  • 634
  • 15
« Reply #10 on: December 30, 2011, 09:48:33 AM »
These are pics of Phase 1 and there is 2 more phases in test and then by spring the super off road system will be through testing .
 Yes you need to run either my strut brace or something to help the top strut mount to insure that they dont bend and the structure stays in place .
 Yes this system dose eliminate the stock upper spring mount and  some fabrication is required . With the ability to increase spring rate you can plan for the extra weight of the addition of a nice winch and bumper ,by having adjustabilty of the springs you can lower the ride height prior to adding the winch and bumper . It was time to make the the lift kits more user friendly and have rebuildable struts.
 For the Phase 1 kit the base price is as listed
 Front only $1225
 Rear only  $255
 total        $1480 plus shipping.
 And if you want to use a strut brace that you already have thats ok as long as long it is strong enough to support the strut towers and the price will change . thanks for looking ,happy wheeling .
« Reply #11 on: December 30, 2011, 03:10:21 PM »
How much travel is there on the strut?
Offline kreator
  • 634
  • 15
« Reply #12 on: December 30, 2011, 03:24:56 PM »
I dont think that I measured it but I think its about 6 1/2" ? maybe more
Offline 96sport
  • 39
« Reply #13 on: January 01, 2012, 10:32:43 PM »
is the shaft bushing in the fox shock the same as a standard fox shock?
Offline kreator
  • 634
  • 15
« Reply #14 on: January 02, 2012, 08:49:40 AM »
I believe that they are the same that they put in the struts on the new Toyota 4x4
