Greetings,
My old plow truck finally gave up, and rather then explain to the wife why I continue to put money into two toys (plow truck + tracker). I decided to consolidate. This meant mounting a meyer's 6.5' plow on the tracker. For reference the plow/subframe was originally on a 89 Chevy Blazer, and I'm just using it for my driveway/neighbor's driveways.
This is basically just the rough in, I'll post more pictures as I fine tune it, and hopefully we'll get some snow, so I can report on how it performs. Let me know what you think, good or bad! Anything I might be missing, or should reinforce etc...
First I extended the front frame to have somewhere to bolt on the plow subframe:
Here's a closer look at the extended front pieces. I still need to add some bracing, but it's welded around the tube and to the side of the actual frame rail. There shouldn't be too much front-to-rear pressure against these mounts, it's mainly to hold the weight of the plow up. Where the plow actually mounts to the frame, there are tubes that run back to the main frame, which should take the majority of the impact.
Here you can see I cut the original plow frame so I could extend the tubes to run all the way back to the main frame(past the crumple zone). Currently in place is approximately 2.5' of black pipe. It's not the strongest, but I had it on hand so we'll see how it holds up.
This pic shows the tubes running under the carriage, there's just enough clearance between the control arms and the tubes.
Lastly, I added a piece of angle iron to give the back section of the plow frame something to mount to. This is actually spaced down about 1 inch.
